If you have a hose kinking, a Unicoil might stop it? Most Auto Shops should have them.
Yeh tried a unicoil, problem is you then don't have enough space on the hose to get a hose clamp on.
insert copper pipe into your oil line and bend it as you need. The bends I have are impossible without kinks, my dad rigged this up for me its fair awesome.
Would have worked, but it's another cost.
To be honest I think the best way is to get a custom braided line made up. No problems, perfect fit, easy. Expensive, but by the time you get to this stage you will be ready to sell your mother to get the farken thing finished :P
Hey Sarge, I had a look at your on road video for SS2 spool up in 2nd from back near page 100. It looks pretty good, and from Stao's dyno chart on it looks like full boost around 3700 for a higher gear.
What do you find that one like to live with? Have you wished it was more responsive or more "top endy"at all? How has it been with this newest actuator you've been running?
My old skyline had a high flowed turbo with 2835 internals. It was mega responsive and made really nice power. This is certainly not as responsive but damn its soooooo enjoyable you live with it. When it comes on hard and you get some nice smooth quick shifts, the power does not stop. That video shows you I think 3rd gear to 6krpm. Had I dropped it in second it would take a second or two to be in full song, but that video was demonstrating the car building boost from low gear, and its pretty good. You can feel first gear runs out of oomph up top, but thats only natural, its not running out, your tires are just spinning so you lose that push in your chair feeling, so what I do is generally shift earlier, around 5500rpm rather than 7krpm. This also helps prevent wheel spin when entering 2nd. Definitely alot better with the new actuator and tune. I was actually very happy with the tune on the soft actuator and didn't intend to go any higher but my tuner said you may as well because the potential for power is definitely there so I did.
With better boost control I think the power line will hold all the way to red line, you can see it tips over abit up top where boost starts to fall. Then you can see the low boost line it holds and keeps going up beyond red line because boost is steady.
This is how it is with my turbo at the moment. I'm only getting full boost by 5000rpm, but my god it's a fun 2000rpm :P
You know what the responsiveness difference is between your turbos and say the SS1PU or whichever is next down in the "SS" range?
It sounds like yours has similar come on to the G3 which flows more. I thought all the SS ones favoured punch over top end hit.
man that really is waaaay too laggy - waiting till 5k rpm to get full boost, but I guess its got something to do with your engine conversion. why not turn the car back to stock, sell it and buy a proper GT-T and work from there?
NA motor will have even LESS lag.
Oh my motors not NA. I imported a smashed GTT from Japan and transplanted everything.
Problem is there is no difference between my car and a 'proper' GTT. It has everything, it was all literally taken straight out of a GTT and put into my car. Everything. The issue is what we wired up and what we didn't. Things like traction control which I never wanted and never knew could cause issues like this. So I need to figure out what it is exactly that is upsetting the ECU and how it can be fixed.
Worst case scenario I have to ditch the NIStune and get something like the ViPEC plug-in.
ah, didn't think about the length.. are you using the standard metal long angled drain pipe off the turbo base? If so could you just use a unicoil with the other type of turbo fitting that is just a small pipe fitting?
Yes, well we ended up just cutting the hard pipe about 2 inches from the bottom and then used two pieces of short length hose with the off-cut hard pipe in between them. The standard rubber return hose was only JUST too short, like I could get it on to both the turbo hard pipe and the sump return, but it was only just on there so wasn't enough room for a hose clamp. So only needed to be extended a little bit.
I'm not really happy with how we fixed it, it's a bit back-yardish so I'll be getting a custom braided line with fittings made up to replace it soon. When it comes to oil and hotness, I don't want to be messing around with potentially dodgy connections.
I was going to join Sarge in the SS2 crew but the castings aren't available til February, and I'm too antsy in the pantsy with Xmas spending spirit so I'm in the G3 brigade instead.
I'll throw some results up when it's all together :thumbsup:
Nah i plan on using nuts bolts and glue
Self tappers and a cordless > zip ties and duct tape > nuts bolts glue.
I also have an RB25 head (DET) that has been VCT deleted to suit RB30 block, has also had exhaust valves retouched. Is a fairly bare head. I will sell this if anyone else wants to venture down this path (or if you need a spare Crans)
I also have an S2 RB30 block yet the crank has gone walkabout (unsure where it is and needs oversized bearings). Has the factory line bolt holts etc for turbo.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
