I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
Cometic plenum & manifold gasket are both steel :thumbsup:
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
Power coming at ya.
Just bought water meth for my SS2 so maybe ill see you in mine....unless your going on e85 :(
No e85 here
My car is still my daily
Would like to be able to go on road trips without 6 jerry cans in the boot :P
Hence me using water meth.
Tank should last 1 tank of fuel on the track or 3 months on the street :)
On this note I have a nice little kit I would like to sell ;)
Come at me bro!
I looked long n hard and thought about hitting you up but unfortunately and no offence but it was my least preferred kit.
Each to their own, but thanks for helping my cause :P
I had planned it for a very high comp DE+T setup, but since then went about forging my DET instead.
So its fairly redundant to me now as my SS1PU will do what I want it to do without the WMI.
Hey Stao, do you have a comparison dyno graph of the G3 with original rear housing flange and the type B one I got from you?
Goto
www.hypergearturbos.com
Under ATR43 and there are dyno readings from both Type A and Type B rear housing from the G3.
Goto
Thanks. If I'm changing from type A to type B, do I need to get a new gasket of some sort for the new flange to go on? I just want to make sure I have all parts ready for the swap over.
I'll have a new dump pipe gasket & new dump pipe, so I mean between the turbo rear housing and the flange plate itself.
Edited by copycutter
LOL thats a good idea. In practice I am told its like having E85 on tap - which helps those who don't have the stuff available.
For me my entire car hits a whole other level of money, time and effort at anything above 240kw. So instead of going for my ultra responsive 10:1 CR 240kw on WMI I have gone for an SS1PU with a DET motor instead. I think I will still get what I want with a little less off boost punch.
The WMI kit would make my setup even better Im sure, boosting power to 280odd shouldnt be an issue.. But the issue there is that SR gearboxes arent so 280kw friendly and neither is my near new clutch. So rather than reinvent the wheel I have worked so hard to create I am just going to enjoy my 240 kw and sell the unused WMI kit.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
