guys FYI the following is 400 bucks delivered:
http://www.ebay.com.au/itm/261045441228?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1390wt_1397
that is a GTR item which will work on any 240mm push type nissan clutch, RB25/SR20 included.
the clamp load is 1100kg so 300kw shouldnt be an issue. drivability will be as close to stock as possible.
hope that helps, NPC are good but you will be stunned @ the price.
Hey Scott,
I think those are the Exedy HD (re-manufactured pink cover ones). The Exedy Sports (silver cover) are the ones you want, the pink ones are terrible, I have had one before uneven wear on the friction plate not to mention you often hear people complain about them on various forums. And pedal feel of Exedy vs. NPC, Exedy pedal is super heavy not to mention people end up breaking pivots as well.
Hey Scott,
The re mfg pink cover is made in Australia, the rest of the world gets the japanese MFG silver cover item. That clutch is coming from the UK.
You can also tell by the box where it says 'exedy racing clutch' with Daiken logos. Where as the said pink cover clutch will come with the ghey 'sports tuff' box.
Excuse my ignorance, but is clamping load all that determines if a clutch can handle a particular power level? I would have thought power delivery, torque, driving usage type etc all affects it also??
The friction material itself obviously affects the amount of torque that the clutch can transmit. If you have a higher coefficient of friction, you get more grip out of the same clamping force. The detailed design of the clutch affects the way that the raw clamping force is distributed across the plate(s), which will also affect how good the clutch is. Simply think of that as the clutch being 95% efficient, or 85% efficient, depending on how well it uses the total clamping force available.
Clutches can be (and usually are) generally "rated" at a certain power level on a given engine because the diameter is essentially fixed across most clutches for that engine and the torque/power delivery variables are almost fixed. Move the exact same clutch over to some different engine and the rating might have to be tweaked. If you take driving style into consideration, then the "power rating" of the clutch assumes a perfect driving style and you would sensibly de-rate the clutch for any non-perfect driving (whether that be the usage model or the clumsiness of the driver, etc).
Yeh start doesn't affect mph much.
Well. Guess that explains our runs at Powercruise. Either we are both hugely down on power, or our turbos are extremely laggy between gear changes.
I say laggy between gear changes.
Im pretty sure if i got a good run i would most likely do around 14.1
Am i changing gears wrong? should i be flat footing the whole way and riding the clutch in gear changes lol???
101mph? That'd have to be a HELL of a launch etc to do low 13s or 12s off that, with slicks at least. 101mph is reasonably typical for high 13s/low 14s on a clean run. What power and type of car are we talking? With reasonable spool I'd be expecting under 200kw from an R33 - if it is much over 200kw then its not a driver issue, it is something to do with how the power is delivered (which could include how much power there is).
I will take mine to the drags after i get my turbo back from Stao and retuned. See how it likes ~6000rpm clutch dumps on MT's
thats it, teach that c*nt a lesson
hopefully i can borrow a go pro and can video me trying to rip the gearstick out the back window (as said by Jez himself on a prior test drive)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
