Hey man going to be going to wsid on Sunday for the off street meet if you want to come should be good also no rush like wednesday nights cause it during the day
You should be in the 12s easy just try and get good rubber
yo, that sounds pretty good. I'll start seeing if I can make it.
How much will the day cost? Is it like weds nights where its $50?
Is that all!!
I hope i prove you guys wrong!! hahah
I guess you cant defy physics :(
What did you end up doing?
I think I raced you at one stage, you had the gopro on brake light? Should have been on the front of the car :whistling:
  • Like 1
Made the calls and cant make it for sunday man. Car has no rego and i got no one available to sign the UVP and take it down.
Let me know when you wanna go for a Wednesday night instead.
If it needs to go to over 8000rpm it is pretty bad, sounds like it takes a while to come on in first gear but hard to tell. What blow off valve is that?
No worries man and yeah it's only $50 it's better on a Sunday as it from the morning so no rush cause it after work and they have it on Sunday once a month
Lith if you mean Hanaldo's car I'm pretty sure it's no bov. That noise is reversion. Had the same thing setup on my car with a G3 and the old "coke can bov gasket" mod for giggles.
Was wondering if that was it, sounded that way. Be very interesting to see if the performance improved without it compressor stalling on every shift....
I don't know for sure, I am not enough of an animal to do that to a turbo so haven't tried the difference but I am picking there is a lot of deceleration when that happens. That will definitely be costing response, how much I don't know... but when you consider how much effort goes into improving response (manifold design, ball bearings, wheel design etc) by increasing the rate the rotating mass can accelerate it seems a bit redundant if you are actively decelerating it again by shutting the door on the pump whenever you aren't at full noise. The fact the surge noise goes away is because the compressor has slowed down enough that it is no longer surging when flowing down a path which will accept less air than the lowest surge line even mapped... Which can only mean the compressor must be back to cruise equivalent rpm at best.
If that is right, the turbo will be spinning slower than if you just cruised at set rpm then stepped on it... I don't know for sure but I would expect the response lost to be measureable.
That was well written. I've read that the sound is generated not by the compressor "chopping" the air to create the fluttering noise, but rather the sound of air cavitating back and forth between the throttle body and the compressor when the throttle is snapped shut. If this is true then the sound may not be due to the forceful slowing of the compressor back to idle but rather just the supersonic pressure differential waves bouncing back and forth until the compressor spins down enough for the sound to not be audible itself. I don't know if this is true or whether your theory is true. I guess you'd need to run the test back to back on the same setup and time it to be exact.
That is close enough to my theory to roll with.
Ever brake boosted? Ie, roll along at a set rpm - lean on the throttle and lean on the brake, just enough to stop the car from accelerating so to load up the engine enough to bring up boost without accelerating away... good for rolling races etc.
Try brake boosting in 4th gear (or whatever gear is safe for the rpm and conditions) then letting off the gas, see if it surges. Now go as low as possible before it doesn't surge when you back off the throttle - between engine rpm and the gauge pressure you are running at that point to not surge you should be able to get an idea of how much lower the shaft speed is relative to the engine rpm and gauge pressure you would have been running at 7000+rpm and full boost.
After that, then consider the amount of rpm the engine will be spinning at in the next gear and how quick the turbo would need to be spinning (relative to the "minimum surge" test) to supply the target boost pressure at those engine rpm and how much acceleration it would need to do to get there. I haven't, and can't do that test - so I'm not sure what to expect but I'd be surprised if you needed to go much (or at all) over 2000rpm/2psi to make surge against a closed throttle audible.
both posts are reason enough for me to try it.
I have a stock S14 bov at home that I will look into refitting. Hope it can hold 20psi tho..
I think I've experienced compressor surge before, at least as I understand it. It feels and sounds totally different to backing off the throttle for the "zututu" fluttering sound effect.
Sometimes when rolling off heavy load and mid rpms with decent boost and no bov (from memory) the turbo kind of accelerates and decelerates in a semi violent and unstable way. It's very noticeable and totally different to snapping a throttle shut without a blow off valve.
Like this effect I mean
Edit: Done some more reading and maybe both conditions are technically surge from an engineering point of view. Not sure, but I always regarded compressor surge as a rather substantial instability to a compressor's behaviour, and the "fluttering" more as reversion/cavitation.
The types of surge you are describing are just far less violent surge than if you close the throttle. I know how you are looking at it, but it seems a bit like serious denial or something - surely you can see it is the same thing, just a very extreme version.
With a turbo there is no solid barrier to provide compression, it relies on aerodynamics to create a higher pressure down stream of the compressor - and assumes that the design of the overall system will ensure that whatever is downstream of the compressor will "accept" enough air to allow air to flow through and out the compressor to allow it to pass more air through it. If whatever is down stream doesn't flow enough at a given pressure you get a bit of a surge noise, which can get as bad as shown in that clip - depending on how bad it is will essentially cause how abrupt the noise is.
In the case of closing a throttle it isn't so much that downstream of the compressor isn't allowing enough air out of it to work right, there is NO airflow out of it. This pushes the compressor HARD into its surge line, the pressure ratio will be enormous and the flow will be miniscule - the compressor will have no option but to try and go to an rpm which matches that flow rate, and quickly. The only reprieve is the engine isn't pumping at full load and therefore trying to keep the turbo pumping back up again - it will just decelerate under an extreme surge condition until it is no longer surging... make it no less surgey, it just at least has an out.
Ok that makes sense, they are the same, except there's just difference in the rate of decel between the two surge types and so the forces the compressor is being exposed to are different.
Back to your above "minimum surge" test. What does it mean if surge is audibly induced at 2000rpm/2psi? Does it somehow indicate the gap in shaft speed the turbo has to make up if you went from 3rd to 4th at full noise?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
