Hmm interesting, is that the same spec SS2 as mine is Stao or has the SS2 changed again since i have had mine done? I will hopefully be getting mine tuned in a month or so.
Stao can I also confirm if this ss2 is the same spec as mine?
Also what was done to hold the boost so well? Mine was at 20psi but went down to 16psi at redline?
Trent Im trying to book a tune with your for next Monday :D
  • Like 1
Sure I can come to see how it performs. Unfortunately yours is an earlier version. I can upgrade it for a small fee.
you will need to preload the actautor to about 10~15mms from base, which can also hold boost fine.
Thanks Stao
But unfortunately already spend a few hundred getting the rear housing heat coated :(
Wow that is what I call A Grade service!
That would be great! Though it seems like a pain in the ass to change the turbo again :/
Is there a page link to the differences? Much of a muchness?
Haven't been able to read the last 150 pages of this thread yet :/
My old ss2 seems to be doing ok just cant hold boost.
This was 20psi bleeding down to just under 16psi. Or does the revised compressor hold boost better?
Hoping to pump 23/24 psi and hold it as much as possible with the Tune with Trent next week
Look at the torque difference at 3k between your SS2 and the latest one.
You'd expect the Neo engine to produce a little more response anyway...I'd think? That latest run is an S2 R33.
That car had a bell mouth dump with a hi-flow cat. On the standard manifold, I was impressed.
Though the tune was on United P100, not 98. But still far from E85.
Just got myself some exhaust wrap :)
Stao do you find any benefit in running the wrap around the intercooler pipe going to your throttle body.
I noticed in a picture a while back that you had it like that
So, finally home from the drags. Had a ball.
Unfortunately was unable to get a clean run without at least 1 pop for boost cut, but its OK. I managed to get it pretty good by the 3rd run with only a minor cut just before I crossed the line.
Final run got my PB and was running 11psi (234rwkw @ 20psi when tuned on 45 degree day), creeping a little after 5500rpm. Lots of wheel spin as they auto greened the lights (no stage), plus it felt like my shimmed diff was pegging on the last run also.
Managed 13.0 @ 115mph. I'm pretty happy with this. The car has an easy late 12 in it AS IS and HEAPS more in reserve once I give it back its missing 20psi.
I am happy to report the turbo is AWESOME and the star of my show. Love my SS1PU. I don't think I will want to go VNT, it is balls out enough as it is. Just want to finish my tune once I am done putting run in KMs on the motor :)
Slips attached.
Congratulations. Not bad for street tyres. Need a set of Mickey Thompson ET street. It knocks about 1.3 secs off.
Factory diff was a problem. Mine was doing single wheel spin at launch.
I've bought a set of tomei pon cams and a two way Kaaz diff to be installed. Hopefully be seeing better results.
For my first two runs I honestly had no issues with traction, it was great.
If I got the launch off my first pass which was a 14.x but did not get boost cut and snatched the gears the way I did on my 13s pass I think it would have been late 12s for sure. At least 12.8.
The tyres help up awesome, that's for sure. Can't wait to go again.
Not sure what to do about boost control though. Is it possible for me to exchange my IWG housing for one with an EWG port off the side?
Not bad but you 60ft is average so you ain't launching hard enough but with street tyres the best I could get was a 2.1
I've run a 12.8@116mph and my brother has run a 12.5@116mph
What wrong with you boost control?
Is boost creep common with these turbos? What is your boost cut, as it must be quite bad creep if you were still hitting it with less preload and no external boost control?
Nonetheless, very nice results all things considered - 13.0 @ 115mph isn't bad for your first outing and if you were down on power delivery, definitely more to be had - especially with sticky tyres :) Its a good respectable time which gives you something which is realistic to be aiming or expecting to beat - so till next time! :D
Its actually just AFM voltage cut, so it has no actual PSI value for when it cuts. Unigroup told me it was set to be around 23psi on the day I picked it up, but that was done on a 45deg day as noted. The very next day it was 10 degrees cooler and I couldn't run 18psi without mega cut.
I've been running it off the can all this time which was 13psi, but last night it was about 10 degrees out west and it was hitting cut at about 14-15psi. After taking heaps of preload out it will seeing close to 14psi in high RPM 4th gear, but 11 in the first 3 gears.
so no major boost control issues I guess.. I'm sure if the boost cut wasn't there it could easily be overcome with enough preload and some basic boost control. Its more so the settings in the ecu.
How easily I cracked a 13.0 with that wheel spin launch though, definitely had 12.8 in it even with the boost cut lol I would have taken another mm of preload out if they gave us another run. Oh well, until next time!
Hmmm I'm not inclined to believe that there would be sufficient air density difference to make 23psi on a 45 degree day = 14-15psi on a 10 degree day, not that I know how to explain that but it does seem a bit strange.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
