Some updates. This is in relation to the ATR43G3 turbocharger. This prototype runs our latest rear wheel, how ever I will be installing it into a smaller rear hopping for more power while retaining the same drive ability.
Test car is currently on E85, the goal would be 350rwkws+ on 20psi with full boost reached by or before 4000RPMs. In which should achieve 300rwkws at 20psi on pump 98 fuel.
Results for above:
I usually make a base model and tune it against its older version. If it is a success then integrate the SS compressor for better response. So both models gets upgraded.
Sorry I didn't get any names in the package, I assume you are the guy from WA correct? if so then yes it has been received. just more power in this upgrade?
Crap i forgot to stick that on the box >.<
Sorry.
Yeh, newer profile like the ss2.
Then if you can send it off to scotty for External goodness
Also PM me the money you need.
Edited by jay-rod
im trying to find some ss2 graphs...
What power would be expected from a ss2 running e85
6boost mani
External waste gate
power fc
z32afm
no exhaust
1000cc injectors
plazmaman plenum
front mount
Excellent, i didn't think it would become that much of a restriction. Good news!
Also, sorry for such a noobish question, but what size is the rear housing on the SS2? .82?
I said external gate in the first post!
God damn i am getting ridiculously keen for this! RB25/30 NEO + 6Boost + TiAL + ID1000 + E85
My poor bank balance :(
  • Like 1
rajab damn i am getting ridiculously keen for this! RB25/30 NEO + 6Boost + TiAL + ID1000 + E85
you did so!
fuark I am blind.. been at work too long today
No the SS3 is about 300rpms laggier then SS2.
The power / response trade is: 1KW:10RPMs.
Take the SS Alpha trailed for example:
SS2 makes 383rwkws 20psi by 3500RPMs
SS3 makes 407rwkws 20psi by 3800RPMs
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
