Great result. more responsive then mine, even thou I had VCT enabled. Its do 190rwkws @4000 RPMS. That would be a great to drive. Have him compared it with other turbos on his particular dyno? if so whats would that be close to on a similar setup?
Nah didn't get time to compare as took all day to tune
Coils kept breaking down on high boost and was running rich at start maybe due to fuel pump upgrade or injector clean but I'm very happy how it drives
Once I get the spark fixed
I will heading to the drags to test it
Hoping for 11s and 125mph
Some updates. This is the ATR28G2 on my SR20det S14, VCT enabled on pump 98 fuel.
Final result of 267rwkws peek 24psi. Since some readings might be depending on dyno. I will run them against a close match of more popular models for end user's power prediction.
Running against a GT2871 in .64 turbine on Greedy easy cams. Since my cam shafts are much bigger. Hines the extra top end.
This particular turbocharger has very similar behavior to a GT2871R.
Yeah some dynos read different
But at the track the trap speed doesn't lie and seat of pants
This turbo atr28ss2 is certainly the best I have had so far response and top end power
I have tried plenty from
T28
Gt2860rs
Gt2871r 48t
Gt2871r 56t
Pe1420
Td05h18g
T518z
Gt3071r t2
Hksgt2530
Atr28g2
Atr28ss1.5
This has all been tested on my 180sx and my brothers old 180sx most on my car over the 5years
All lowmount t2 and even comparing to big name jap brands and yet the best so far has been the hypergear atr28ss2
I said best power and response
So yes it comes on alil later 200rpm
This 3800rpm but 25psi the pe1420 3600rpm 20psi
220kw pe1420
280kw atr28ss2
Extra 60kw I know what i would rather
The Pe1420 runs out of puff up top yes it spools up quick but only ran a 13.0 with this turbo and did a 13.2 with the t28 both similar mph 110
Edited by hy_rpm
Oh yep, I read the post a couple of times thinking you may have meant that and it still seemed you were saying both spool and power. Yeah that makes sense, our testing with the PE1420 not flowing much more than stock but it was crazy responsive - 20psi at like 3100-3200rpm... but was choking the engine by ~17PSI, 16G on it now holds 20psi no issues but substantially less mental in response and needs till 3600rpm for 20psi.
Sounds like the 28SS2 is a good unit on the SR
I think Tao has hit the head on nail for sr20 t2 low mount turbo
After numerous testing and even my testing back to back same car and mods
Against the
Atr28g2 .64
Atr28ss1.5 .64
Atr28ss1.5 .86
More test driving it with another set of coils and another set of iridium plugs gapped to .6mm seems to have fixed the miss on high boost for now but just blazes the tyres in 2nd
Going to need semis slicks for the drags
Thanks for the feed back and looking forward to some drag video footages.
This is an update based on our SLSS2 Turbocharger, Is the SLSS3. This particular one is aimed to produce 400rwkws on E85 with optimum response. And of course I have made a ball bearing version of it as well as bush.
It is running off an TD06 based, 10cm T3x turbine housing.
This is an update based on our SLSS2 Turbocharger, Is the SLSS3. This particular one is aimed to produce 400rwkws on E85 with optimum response. And of course I have made a ball bearing version...
Of course you make a new version just after I get the SLSS2 lol
Edit: What is different between the SLSS3 and my version of the SLSS2?
Edited by KerrodR33
Looks similar, yet two very different turbochargers. SS3 is no longer using L2 turbine, it is larger on both compressor and turbine end. Obviously in usual situations more HP is based on trade for response. From experience, 20psi will be at 4100RPMs, will post up result once dyno reading available.
  • Like 1
Getting the slss2 tuned... Longest few days of my life :( First had a massive exhaust leak so ripped the whole manifold off and the manifold gasket was fubar! Tuner fixed that for me and now we are hitting 100% duty cycle on my injectors and only making 130rwkw >:(
They are brand new 740cc deatschwerks and I'm using a brand new walbro fuel pump!
Blocked fuel filter maybe? Just want to curl up and cry lol
Check fuel pressure as the injectors are opening at 100%duty but the fuels not getting to the cylinders as it's needing that much duty cycle/opening time for enough fuel to make 130kw
Or it's leaking at the manifold
Who is you tuner?
Who is you tuner?
My tuners name is Rick Campbell, great bloke and only guy up here in Darwin willing to tune my car. He is swapping out the fuel filter now as we speak so hopefully that shows results but if it's not is it possible fuel pump is a dud? Brand new from kudos motorsports so I'm sure it's a genuine walbro.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
