hypergear Posted December 11, 2015 Author Share Posted December 11, 2015 Uploading some results posted from a NZ fan today. I think the NZ dyno HP determination equation is in DIN. Latest ATR43SS2 internally gated bolted to the factory manifold on S2 RB25DET.- Greddy knockoff plenum- 1000cc xspurt injectors- 80mm bar and plate intercooler- custom 3" piping- g4 plugin ecuFinal numbers were 331kw @ 500nm at the wheels on 18psi boost on 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7651979 Share on other sites More sharing options...
hypergear Posted December 11, 2015 Author Share Posted December 11, 2015 Hey Stao What can you do to my old ATR43G2.5 -> Which was sent back to become a now SS2 a year or so ago. if u remember. Is it worth sending back for some loving? Im making a healthy 300+rwkw at the moment. Can you get that close to your atr45? or is the housing to small for that? Want some extra juice for Racewars next year Yes can upgrade few things to make more power. I can't remember what configuration it might be in. Best email few photos first. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7651980 Share on other sites More sharing options...
Manuel Kasko Posted December 11, 2015 Share Posted December 11, 2015 Any update on r33 high flow prototype? I'm keen to get this on my E85 Neo setup if it proves to be similar response to the SS1PU. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652023 Share on other sites More sharing options...
hypergear Posted December 12, 2015 Author Share Posted December 12, 2015 Thats about as good as they can get, I'm out of turbine housing for any better efficiency compressor. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652063 Share on other sites More sharing options...
benl1981 Posted December 12, 2015 Share Posted December 12, 2015 Me to so is the r33 high flow prototype in full swing production now? Looking to use it on an r34 neo also and maybe e85 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652110 Share on other sites More sharing options...
hypergear Posted December 12, 2015 Author Share Posted December 12, 2015 Yea. cost $990, includes large internal gate assembly, high pressure actuator and oil line. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652140 Share on other sites More sharing options...
Manuel Kasko Posted December 13, 2015 Share Posted December 13, 2015 From your experience, is this as good as the SS1PUIs it just as responsive and can it make 300rwkw on E85? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652467 Share on other sites More sharing options...
hypergear Posted December 13, 2015 Author Share Posted December 13, 2015 Yes. probably make more power then SS1PU. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652481 Share on other sites More sharing options...
thommo458 Posted December 13, 2015 Share Posted December 13, 2015 With the atr45 is there a recommended dump for best results? Brand name Bell mouth, China or a split dump? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652508 Share on other sites More sharing options...
hypergear Posted December 13, 2015 Author Share Posted December 13, 2015 3.5 inches turbo back will work te best. Bell mouth. Or 3 inches with exhaust tee. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652558 Share on other sites More sharing options...
kingtube69 Posted December 13, 2015 Share Posted December 13, 2015 Stao any recommendations for exhaust brands/models and dumps that suit that? I've found the Tomei Expreme is 3.5 from the cat back but NFI about the dump pipe 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652633 Share on other sites More sharing options...
thommo458 Posted December 13, 2015 Share Posted December 13, 2015 Cool cheers, have you got a handful of atr45 install photos? Wouldn't mind seeing the intake setups on r33 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652652 Share on other sites More sharing options...
kingtube69 Posted December 13, 2015 Share Posted December 13, 2015 Cool cheers, have you got a handful of atr45 install photos? Wouldn't mind seeing the intake setups on r33 Hi Michael, I have this turbo on my R33 - I'll post some pics below. If you want anything more specific let me know and I'll go pull the airbox off for you Overall can't see much so it looks stock (No problems with cops). The only thing that stands out is the silicone joiner and the braided oil line for the turbo. Will be invisible with a heat shield on it. 10mm spacer was needed for it to clear the block and you will need 45mm and 55mm studs if I recall correctly for the turbo to manifold connection. Must have a metal intake for the turbo too. 2 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652697 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 13, 2015 Share Posted December 13, 2015 if anyone wants my #scotty_nm35 3" intake with 3" to 4" silicon reducer & an alloy extension piece (if you are deleting your AFM), it's up for sale soon... Mine's a little different as it doesn't have the BOV return and the breather line it mounted slightly different to delete the factory hardlines, intake mates up to the factory airbox (if you need it). 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652700 Share on other sites More sharing options...
kingtube69 Posted December 13, 2015 Share Posted December 13, 2015 I'll take the AFM delete pipe if it will mount up to the factory airbox depending on price, I just went MAP and ceebs making a delete piece myself Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652706 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 13, 2015 Share Posted December 13, 2015 it's just silicon and a short piece of alloy? hahah Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652712 Share on other sites More sharing options...
kingtube69 Posted December 13, 2015 Share Posted December 13, 2015 All good, I was thinking it was like the HKS afm delete that connects to the stock box Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652715 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 14, 2015 Share Posted December 14, 2015 buy one of these things, then connect silicone to it then to the alloy piece.. done! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652757 Share on other sites More sharing options...
kingtube69 Posted December 14, 2015 Share Posted December 14, 2015 Oooooh, I was just thinking about that. I have one sitting at home anyway Thank you! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7652771 Share on other sites More sharing options...
hypergear Posted December 15, 2015 Author Share Posted December 15, 2015 Results from an Externally gated SS2 from externally gated R33 Rb25det E85 fuel. Note the rise in torque as engine revs out. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/566/#findComment-7653779 Share on other sites More sharing options...
