Uploading some results posted from a NZ fan today. I think the NZ dyno HP determination equation is in DIN.
Latest ATR43SS2 internally gated bolted to the factory manifold on S2 RB25DET.
- Greddy knockoff plenum
- 1000cc xspurt injectors
- 80mm bar and plate intercooler
- custom 3" piping
- g4 plugin ecu
Final numbers were 331kw @ 500nm at the wheels on 18psi boost on
  • Like 1
Hey Stao
What can you do to my old ATR43G2.5 -> Which was sent back to become a now SS2 a year or so ago. if u remember.
Is it worth sending back for some loving?
Im making a healthy 300+rwkw at the moment.
Can you get that close to your atr45? or is the housing to small for that?
Want some extra juice for Racewars next year :P
Yes can upgrade few things to make more power. I can't remember what configuration it might be in. Best email few photos first.
Cool cheers, have you got a handful of atr45 install photos? Wouldn't mind seeing the intake setups on r33
Hi Michael,
I have this turbo on my R33 - I'll post some pics below. If you want anything more specific let me know and I'll go pull the airbox off for you
F4591ECD-F6E9-491C-A7C4-5B795C53B68A_zps
45409CC0-085C-466F-8EFD-4B1748DB1656_zps
D6EA2BEB-2222-4A0F-9EDD-57A03124BDB6_zps
4B7D885D-D255-40F7-B5E5-6B4CF9633DCD_zps
324A1E0A-449F-49A4-827A-85B765B7E4C1_zps
Overall can't see much so it looks stock (No problems with cops). The only thing that stands out is the silicone joiner and the braided oil line for the turbo. Will be invisible with a heat shield on it.
10mm spacer was needed for it to clear the block and you will need 45mm and 55mm studs if I recall correctly for the turbo to manifold connection.
Must have a metal intake for the turbo too.
  • Like 2
if anyone wants my #scotty_nm35 3" intake with 3" to 4" silicon reducer & an alloy extension piece (if you are deleting your AFM), it's up for sale soon...
Mine's a little different as it doesn't have the BOV return and the breather line it mounted slightly different to delete the factory hardlines, intake mates up to the factory airbox (if you need it).
12108237_1139761716052956_84809291911063
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
