cant be intake restrictions, 4" intake with K&N pod, 3" custom IC piping....motor was running standard turbo before and was pretty stock..
The car feels good, it has brand new 255 federals on the back and it breaks traction when it hits boost in second, used to do it in 3rd with the old tyres..
Heaps weird...
What ecu? No changes with fueling and timing makes you wonder if the changes are being written to the ecu.
Nistune was playing up like this on the Stagea last year with this sort of issue.
power fc... the changes were definitely writing because the wideband was registering the changes and the timing eventually caused the knock levels to increase slightly as well...
Hypergear turbos love restrictions :laugh:
I feel your pain though. Car has been sitting in the shed for a couple of months now, thinking about what it's done :glare:
Has it learnt its lesson yet?
Apparently not, it hasn't fixed itself yet. Now it's throwing a tantrum with the drivers seat, so it's in the naughty corner until I get back from Europe.
we both had no idea.... the car wasnt responding to anything... threw more timing= same power, richer=same power, leaner=same power wtf?
That means turbo's pushing some thing's limit which power band does not responds to the tune. I think its in the exhaust or some where, try drop it and see if any thing changes. Was it a plumb back external gate?
Normally cooler restrictions would drop heaps of boost, and the cooler would be burning hot on the cool side. So its not the case.
Also if you are in Sydney might be worth while visiting Toshi for a quick check up.
Why is the engine speed increasing then going back to zero? But speed increases gradually
I could be way off here but that torque looks quite high compared to power so maybe its getting wrong speed signal?
Rpm increases,decreases,increases then falls off
Edited by t_revz
yeah the dyno guy said that for some reason some nissans do that weird shit with the rpm... he said it wouldnt affect anything but.
The power graph really supprised me because it feels nothing like that...it actually has nothing for ages then all of a sudden kicks in massively and frys tyres but that graph makes it look very linear.... very strange
Just got off trents dyno
265rwkw with coil packs missing all over the place
19.7 psi down to 15.7 psi drop
Trent thinks it will hit close to 300rwkw once we sort out coilpacks and boost drop
Internal gate, note sure about the extended arm? Im guessing so.
Retune booked it for next Thursday.
Have purchased yellow jackets and will put in new spark plugs for the tune.
Trent made a suggestion that the boost drop maybe due to the stock BOV on the GTT not up to task? But were not 100% yet until I do the coilpacks and go back in for a retune.
Anyone know what the power limit on the stock BOV is before you need to be concerned?
He said to get a GTR one if it is the case.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
