  • Replies 219
You might be right Moei. Ill have to wait a couple of weeks to find out for sure when I get a chance to get back to the dyno.
The car is driving great on the road, a wall of power from 4K Rpm all the way through to 8K Rpm. Theres just nowhere for me to go flat out through 3rd gear and on, Id be just a little over the speed limit :devil:
the clincher in my opinion is the Nismo gal. radiator guide plate. Whats the Nissan part number for that one Bakes?
would have been nice for Wayne to let us have a quick run on the rollers today after the Toyota club had finished.
Dave tells me the cat that was fitted represented a significant (up to 40%) restriction in the system. He owns an exhaust shop so his knowledge is reasonably accurate.
The numbers up to where the power starts to nose-over are all excellent for the set-up, and we by no means pushed the car hard....but there is something stopping it making more power, winding more timing, less fuel or more boost to try and push power figures is pointless at this stage. Its a method of just trying and testing a few ideas when Bakes comes back from working interstate to get the power where it should be at this level of tuning. With the wheels fitted to the car and the level of tuning the car has now i estimate the power is down about 40-50KW of where it should be...yes a restrictive cat can rob you of that.
Edited by DiRTgarage
Paul, Im working as a contractor for Nismo in relation to the Gal Nismo radiator gap plate.
I can custom make them and sell them for $450 if anyones interested, lol :(
OK part number is 024U-225371 or 024U-BAKES1...lol
I hope you have arranged with Christian (Prank) to operate as a trader on this site.
one vote for fuel pump
lol
a lack of fuel would have shown up on the dyno...we had to take fuel out of it.
its holding its afr's dead flat to redline.
ive had my car not make anymore than 10psi boost due to a stuffed cat and soon as it was unbolted it went back up to 18psi, thats with a 3' magic cat too, blocked/restrictive cats can kill power bigtime, definately capable of gaining 60kw+ if the cat is blocked or just ultra restrictive.
Hey Bakes hopefully all gets sorted so you can get that magical 300+ mark. Ive just replaced my titanium exhaust with the Varex system and im happy with the outcome. I was quite surprised how much better it ran after installing a high flow cat. Though i miss the loud sound i had, the car still sounds great and when i push the remote its full on stealth mode (no cam burps)..
Cheers for the comments guys!
Great info Unique1, Thanks. Definately could have been my problem then. We will see.
Fatz, I have Nismo fuel pump.
Huy, Thanks, you might well change your cat to after we see my next dyno result in a couple of weeks.
did u bright sparks think of dropping the exhaust after the front pipe to see the effect?
yes we did think about this, however it was not possible to do because we were running out of time and it was 10pm at night by the time we hit the power brick wall and running the car with no exhaust would have been bad.
very nice car bakes.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
