im always up for tips on how to reduce lag, and recently saw a dyno graph with a gt55 turbo on a supra which had a curve like it was a t04z.
the supra was stroked to 3.4L and some nice cams but he also mentioned that half the reason why the spool was so insane was because he had a "spool valve"
from wat i understand its basically using a split pulse manifold system and blocking off one side to force the exhaust cases through the other one. resulting in more restriction thus faster PSI buildup.
any professionals care to explain this tatic any any pros and cons?
honestly never heard about it until now
btw does anyone actually sell these in aust?
Edited by VB-
https://www.sau.com.au/forums/topic/264645-spool-valves/
I see thread pop up about this every few months on other boards. I've never actaully seen anybody use it other than that one write up with the Supra, but it requires a NON-split pulse/twin scroll manifold to work. It's interesting for sure, but I've got a split pulse manifold, so I'm not going to be a guinea pig. How much do they cost?
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4523705
I don't see how this would be effective at spooling a turbo any faster. Basically this would create more pressure on the manifold side of this valve as the exhaust gasses try and pass trough what is a smaller opening and as i have been taught increased pressure does not increase flow through the same sized hole.
Basically this is choking your exhaust. The best way to spool a turbo is to get as much exhaust gas onto that turbine wheel as soon as possible. Putting a restriction like this in place i can't see how it would work as you are basically halving your exhaust flow with the restriction like that in place...
use this calculator ( http://www.efunda.com/formulae/fluids/calc...iction.cfm#calc ) to see that increasing the pressure without changing the pipe diameter does not alter flow at all. change the pipe diameter however and watch the flow increase.
I wouuld say that there would be a optimal size in exhaust header diameter to keep flow and gas velocity at an optimal level.. but to my mind a contraption like this wouldn't help.
My two cents, hope it helps.
Not to mention companies like HKS/GARRETT etc probably don't make these and that would be a fairly good indication as to whether they work or not.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524082
It would work by accerlating the gas flow into the turbine at low revs. so instead of having a large area of slow moving gasses they have a smaller area of high speed gasses.
I could work in theroy but without having serveral diffenent cars with it to back up the results its all hersay.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524108
The fact that they could improve spool etc definitely makes sense - its effectively like hugely tightening up the turbine a/r, though ultimately I don't like them - they would make the breathing of the engine very inconsistant and even when its open I really can't see it doing anything other than creating a restriction. All the dyno plots I have seen with hem being used seem to finish at the point the "normal" setup catches up... what happens to top end flow?
There may be a better way of doing the same kind of thing.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524149
i agree with lithium, causing a restriction would basicly rack up psi way faster.
as far as top end, i dont know how this would be possible due to restriction. but they claim it gives a 25% INCREASE in top end and improved spool.
if i can get my hands on one id defiantly be interested in trying it out.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524220
It effectivly halves your a/r then opens up at a certain psi when the turbo is well on it's way to being spooled. It's kind of like a poor man's variable geometry turbo. I'd be worried about it standing up to high temps. I have no doubt it works, but how well and at what cost/pain in the butt are my questions.
And basing whether or not something works off of whether or not HKS or Garrett makes it is rediculous.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524309
I did once see a diagram of something along those lines but I smell marketing rather than function driving this idea .
Firstly to have it work properly you'd need an open collector manifold with that thing between the manifolds mounting flange and the twin scroll turbine housing .
What it does is feed all the engines exhaust gas through one side of the divided turbine housing until the plates throttle opens up .
I image once the boost , or preferably the exhaust manifold , pressure reaches a set point the actuator opens the throttle valve .
The downside is that the throttled side won't flow as well as the open side and the open collector manifold won't work like a true twin scroll system .
I think a 3.4L 2JZ type thing should not have dramas making torque off boost or kicking a big turbo into life if the manifold/gates and the overall state of tune is on the money .
Gimmick I think , cheers A .
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524621
oh that and they are 500usd for a t4 flange.. a guy on ebay made some the SAME for $100 but got sued by sound performance coz they have a patent pending on it...
evan though borg warner patented the concept using a valve in the actual turbine housing....lol
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524719
$500 isn't too bad if it works I guess. Holset does the same kind of thing with variable vanes in the exhaust housing effectively changing the a/r. It makes a 600rwhp turbo spool like a stock turbo, but the problem is it's electronically controlled via the factory Dodge ECU and people have yet to make it work real well in a non-OEM application.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524842
It's already been around for a couple years. I think they were having some kind of "development problems" which is why they put the idea out there, but didn't sell it yet. Maybe making it last on high hp daily driven cars is still a big hurdle.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525225
Hmm interesting idea, never come across it before. However when its fully open, surely the side with the valve in it would be at a greater restriction than the other side causing a larger pressure build up in the runners for cylinders 4, 5 and 6. This wouldn't have a slight negative effect?
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525235
you would think so huh?
but they claim it would ACTUALLY increase top end by 25%.......dunno how but insane if true.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525307
Obviously you would have to run a normal (non split pulse) manifold, and a split pulse turbine housing ....... when closed all the exhaust gas is re-directed thru one side, generally 1/2 A/R of total housing rating. So spool up would be same as a much smaller housing, and top end of the larger housing. There would be a slight restriction to the runner with the plate in it obviously, and so i would say power could be slightly lower , top end. Depends on how hard the housing is working to make the power you are at.
As i mentioned , this was a factory setup on the S4 Rx-7. It however , used a setup more akin to a wastegate flap, not a butterfly.
I wonder what materials they used, as that flap looks quite thin. You'd think there could be probs with it sticking too with the huge heat range it would be getting.
Gary
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525393
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
