Hi all,
After i had my car tuned on E85 we could see that boost was dropping higher in the rev range.
After trying various things to keep the boost steady we determined it was too much back pressure in the exhaust system (even with a screamer)
I have since plumbed the screamer in and now boost has dropped again (21psi to 18psi) which i think confirms the fact that the back pressure is reducing the boost in higher RPMs, now that the added gas from the wastegate is joining the exhaust system.
What can i do to reduce the back pressure in my exhaust system??
I was thinking the turbo is too small for my setup and was considering an upgrade.
https://www.sau.com.au/forums/topic/265047-reducing-back-pressure-in-exhaust/
Can't help you if the turbo is to small, but as for exhaust, do you guys use "cutouts" down under? They are pretty popular in the states, like this combined with this.
i dont think that's gonna help him... running a 2.5" cutout on a 3" system...
bigger gate maybe? and keep the screamer
I didn't look and see what size dump it was, I just chose the ones closest to the top of the list. They have them in 3" and larger.
Bigger wastegate does seem like a good option to me, but I think somebody with GT3037 specific experience could say better. I had a single 50mm WG and I would loose boost on the top end. I ported out the manifold WG runners and and WG, then it would hold boost all the way to red line. As the weather got cooler however, I then started having boost creep problems, so we chopped up the manifold at the WG runners, re-angled them, and added a second 50mm wastegate. Now it holds boost rock steady at 1.7 bar and we were able to put 12 degrees of timing back into the MAP at peak torque due to a LOT lower backpressure in the manifold.
Upsize to mandrel bent 3.25 or 3.5 inch exhaust using in 5 inch body metal 100 cpi cat with 3.25/3.5 inch in/out of the cat with X number of straight through mufflers to suite your noise requirements.
Edited by juggernaut1
Some data I came accross recently regarding the Ballistic Cats http://www.surefloexhaust.com.au/frame1600x1200.htm:
Summary info from the above URL - as you'll see the 5 inch body seems to be the way to go
r. Measurements: -
5” cat with 3” ends - 706cfm
5” cat with 3.5” ends - 885cfm
5” cat with 4” ends - 1015cfm [/i]We tested the “Magic Cat” and “Metal Cat” using their own 3” fittings welded to each end and compared the flow with our Ballistic Cat with 3” pipework welded to the ends and here are the results:
Magic Cat 4” body with 3” ends - 546.6cfm
<LI>Metal Cat 4” body with 3” ends - 629.6cfm
<LI>Ballistic Cat 5” body with 3” ends - 706.2cfm
There are some rubbery figures going around. Magic advertise the flow of their 4” cat as 750cfm and their new 5” cat as 890cfm. These tests are obviously done with no ends on the catalytic converter. So if you compare the 5” cat from Magic @ 890cfm against our 5” Cat with 4” ends @ 1015cfm it shows ours flows 125cfm or 14% extra. This is extra performance. This cat is also available as a “Bolt-On” replacement unit for Nissan R32, R33, GTR, GTST, GTiR Pulsar, 180SX and S13 Silvia.
So assuming your running 3" in/out on your metal cat - it is flowing 629.6 cfm..........................compared to a 5" body Balistic cat with 3.5" in/out would be 885 cfm (or 1015 cfm if you went 4" in/out)
Where is the restriction?
Drop the exhaust before the cat
Then from after the cat
Then from the next flange near the rear (if there is one)
3.5" should be flowing enough, no question there. I reckon its also the cat
how much back pressure do you have in your exhaust? mine has about 4psi on 330rwkw and nearly 8psi!!! at 360rwkw.
need more information, if you have back pressure how much do you have ? id say the issue is your turbo not your exhaust, my 3" can make 370ish with no issues.
I had the guys at the shop look over everything for me, they said all looked fine. Im thinking ill try a 5" body cat.
Not sure how to measure it Anth, but i agree the system should support well into the 300s easy.
agree with the others, id say its in the turbocharger housing
how is the manifold setup, it could be the backlog also
Manifold is a 6BOOST item. Im leaning towards the turbo itself. With the extra timing and boost added for the E85 tune id say the turbo is almost at its MAX.
Some will say you can get more out of it but my tuners dyno reads lower than most.
Maybe its GT35R time :P
no i mean do a run, drop, do a run, drop another place
you'll soon see whats causing it
Maybe its GT35R time :D
Get the boost drop sorted and it will make some decent power. :banana:
Plumbing the wastegate in to the dump kills boost a fair whack. :S
E85 produces more exhaust gas than regular pump fuel so no doubt not helping your problems.
As others have mentioned drop the exhaust after the front pipe to see where the restriction is.
All though its likely to be a bandaid you may wish to look at fitting the gate with a spring to suit the boost your after, then use the EBC to tweak spool.
Another option is to fit a smaller gate that will reduce the surface area and prevent the gate being blown open once the pressure backs up.
If you have to redo the exhaust consider a 3.5-4" dump and then if need be taper it down to 3-3.5" or twin 2.5" after the cat. Works for the XR6T's to make decent power and keep noise under wraps. Twins do an excellent job of keeping noise down while still flowing damn well but $$. :P
Some times if a workshop is busy they will say it looks fine but they really don't know until they drop the exhaust and find out the good ol' fashioned way.
Edited by TheRogue
just letting you know -
I have a GT3037 with a 0.63 rear and a 0.6 compressor cover, 3 inch off the dump, 3 inch pipe through the cat, and 3.5 inch all the way with a muffler and cannon. Standard exhaust manifold, and intake. Standard cams, standard head.
Car is making 310rwkw and holds 20psi from 3200rpm in third right to the limiter and doesn't spike or drop off. I have a gizmo boost controller and a fairly tight 9psi wastegate actuator.
What size rear housing do you have? I don't recommend the 0.63 unless you have water meth. 0.82 is the best.
Edited by The Mafia
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
