It's in no shape to be sold for a parts car. A friend of mine was investigating buying this before it went on ebay but everything is wrong with it. I would not be surprised to find a large hole in the bottom end of the engine and a cracked transmission housing.
https://www.sau.com.au/forums/topic/265262-r35-wrecking/#findComment-4534784
Interesting to see the price he's asking for the motor. Does anyone have an actual figure for a replacment motor from Nissan? (actual figure, dont just post up if you're guessing)
In the region of 4.5 million Yen.
https://www.sau.com.au/forums/topic/265262-r35-wrecking/#findComment-4539240
Every single rim is bent, all the rotors need new disks and who knows if the calipers and hats are salvagable. At least one is probably not. The suspension is completely gone.
mm wodnering what happen to that car, did it ran off a cliff and burst into flames or something...
yucckk
https://www.sau.com.au/forums/topic/265262-r35-wrecking/#findComment-4539562
I'm sure it's not the 1st and it won't be the last. These things generate speed so effortlessly and I'm sure there are going to be plenty of owners who have no idea about cars but think the car will do it all for them.
My first thoughts when driving one was - plenty of people will hurt themselves in one of these!
https://www.sau.com.au/forums/topic/265262-r35-wrecking/#findComment-4539702
My thoughts exactly, old rich poofs that can barely park let alone drive a lethal car like this....
https://www.sau.com.au/forums/topic/265262-r35-wrecking/#findComment-4540213
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
