They are not actually bots, but people that sign up, post (if needed to activate PMs) and then use a script to PM everyone on the site, person by person.
They have hit MANY sites, a simple google of the username will show this.
The Link SHOULD NOT be clicked, the PM should be deleted immediately, and a moderator/admin notified of the user so that the account can be disabled, and the account's sign-up IP address should be blocked from accessing this site.
OzMazda.com took the step of blocking the IP address range the user signed in from, and has been clean ever since, but prior they had 3 different attacks in the space of a week.
B.
  • Replies 63
i got it too
Personal Message
brickerza
View Member Profile
Add as Friend
Send Message
Add to PM block list
Forward PM
Find Member's Topics
Find Member's Posts Weekend, Today, 08:36 AM
Rank: RB20E
Group: Members
Do it now!
Time to upgrade the anti bot join page.
Its not a bot thats joining up - its actually a human completing the registration process.
Then they proceed to run a script/bot once all of it is complete.
Next time - please post in the one thread that we have dedicated for this.
http://www.skylinesaustralia.com/forums/Pm...or-t265283.html
Thanks
^ if your selling goods, ie wrecking a car with 20-30 parts.
You're going to get triple that in PM's... So it's VERY hard to decide on a limit that doesn't impact users
There is a IPB release coming and so on, Admin will have to think about how we set the limit
I mean to set a limit on how many PMs you can send, not receive. I think very rarely do people send more than 20 PMs a day. Maybe make the limit 50 then... Even that would make it less spam-worthy than now.
Anyway, hopefully the update will help kill spammers.
Maybe make the post limit only 10 posts or so, most spammers can't be bothered making 10 legit posts and anyone that is serious about selling parts would surely have been part of the community and have 10 posts anyway, also its not stopping them from sending PMs its just limiting how many they can send in a day.
I guess wait and see if spam like this continues to be a problem, if it stops at only these two events then that kind of action probably isn't necessary.
edit: A better option would be to add captcha phrases (enter in some weird looking text) to people sending PMs with less than 10 posts, like you see on most online signup websites. I don't know how difficult this would be to implement, however Vbulletin? is pretty popular so someone has probably already made a mod like this.
Edited by Rolls
Like i said, 20-30 parts, that means at LEAST 40-50PM's, and that means generally you would be replying - which means one user sending.
Its not like we haven't already thought about it all :P
Its not like we haven't already thought about it all :/
Just go another today (deleted member already)
As i dont use PM's much it might be a dumb question, but is there a timer limit (like posing on the forums) for sending PM's?
IE
You can only send 1 PM per minute or so?
It may at least slow down the amount of PM's they can send
OK so we shouldn't be receiving any more spam PMs. I've put in two methods of blocking this:
If you're just a regular member then you can only send one PM every 5 mins.
SAU VIC, WA, QLD and NSW club members, mods, admins, traders and contributors can send unlimited PM's... the assumption here is that we've verified who you are so we trust you.
Also if your postcount is below 10, then you can no longer PM. This will hopefully weed out people who sign up and then supply the login to bots.
I'll run a few cleanup queries tonight which should remove the spam PM's from your inboxes if they're still there.
If you do get anymore spam PM's (ie after the time I posted this) please let me know, as it means the bots are circumventing the above patches.
Thanks for your patience guys.
lol unfortunate side effect. I just can't believe how much trading goes on by people who don't contribute any useful posts on the forum.
At the very least post up a Intro post in the Newbie section and have a conversation with people, it'll get you to 10 posts pretty easily.
That's a bit rough! Why don't you just make it 5 so they can't do it in one sitting?
Well whats worse?
People getting infected by a virus because of spyware - or some mild restrictions to stop it?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
