Sort of worked...
Aaron and I went for a squirt today, he looked at the gauges while I drove. We found my ecu definitely opens the throttle 100% at launch, but only if the brake was off for a second or two beforehand.
I looked at the ECU diagram and found the brake pedal input wire, not knowing if it would put the car in limp mode or if the brake lights would work, I snipped the wire and backed the car out.
The brake lights worked, and now I had 100% throttle at stall. A drive told me the abs still operated and the takeoff was much better, with the car hitting the 4000 rpm stall limit off the line with little effort.
I will let you know how the car drives over the next few days and if there are any side effects but for now it looks like Pipster pointed us toward the holy grail. :cheers:
Yep and can't believe how simple It really was obviously scotts is running off a built box which means I'm also testing it out for the next few day on the stock box to see if it handles. Scott now has an advantage with the high stall.. On my gbox it's improved a little but because I have a 2000rpm stall I can't do much ATM. But In saying that I can now boost up to 8-9psi on stall with 100% throttle and launch the bastard much better than before. I cant believe we did it, hopefully this will save us over $1000 each by not having To go gzone or nismo anymore!
Woohooo, that's brilliant !
I'll give that a go myself. Will do the before & after tests under same conditions of course, to try & take the 'subjectiveness' out of the equation.
I love low (or zero) cost solutions that give great results. No one can be dissapointed hey
If you want to try it, its pin 55 on the ecu. Its a pink wire with a blue line.(around the middle of the plug.) Just make sure you tape up both snipped ends well. :thumbsup:
(Dont hold me responsible if you damage anything please.) lol.
i rekon the nismo already has this out of the box thats probably why we have better throttle response........
but this is a shit loads cheaper lol
can you confirm this by getting hold of an informeter and stalling it up, before chopping the wire?
would be interesting to know, as i know andys impul is only doing 36% on stall as standard
his is KNOWN to have the throttle limit.
are you guys 100% sure there IS a performance increase?
heres my theory, the informeter is reading the throttle input from your foot. the ECU limits THAT signal to 38% (or whatever) due to its programming.
i have an informeter mate, ill be driving to work tomorrow so ill check it out in the back streets. wont be chopping any wires yet
yeh because before when scott would stall, it would hold him at 2000ish RPM,, now it limits him to his high stall converter.. which means the extra opening has increased, i also noticed a 5psi increase from where it was before for mee..
im sure he did lol
im glad we all worked together to get past this problem :)
now craig and i cant son of rajab our nismo all over you guys :(
Does that mean if this works out everyone gets membership to the awesome forum? :nyaanyaa:
im sure he did lol
Nismo awesome is still awesome; but free awesome is the awesomest kind of awesome.:thumbsup:
'Cept for boobies...:thumbsup:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
