So recently Ive picked up a fairly damaged s13 for a project car, mechanicly the car seems fine but the panels on the car are wrecked and I have almost finished the process of replacing the wrecked panels and will be giving the car a respray. My goal is to use the car as a daily driver (so i ca garage my 34 to drive on sundays), but also use as a sleeper. Of course Im going to be doing an engine conversion but to decide the type of engine im going to put in the car is seeming to be almost to difficult for me. So here are a few ideas that have come to mind, and please take note that the car needs to be automatic.
1jz
2jz
rb25
1uz
rb20
these are jsut a few engines ive had in mind. currently im leaning towrds the 1uz as its something a bit different, 1uz s13's are rarely put together, and the engines are strong and i can lean towards either turbo or supercharge.
1jz,would be the obvious way to go as th engines are quite strong and standard internals can handle quite a bit of power as im looking at keeping the engine relatively standard and not opening it up, im aiming more towards an affective power to weight ratio and the 1jz are quite light in comparison to an rb25.
R25 would be a more straight forward instalation, I have more experiance with the rb25, I have parts lying around that would make good upgrades for the engine but with the engine being a bit heavier than the others Im concerned about the weight distrabution and would prefer not to hafto do too much to the firewall to even up the weight.
2jz, from what I understand these are a difficult engine to put into the silvia, the sump is a problem so you need to find a 2j from an aristo for a good match and i dont know of any conversion kits made for the 2j and s13 body.
rb20, tough as guts but lots of potential but will require alot more money put into it to get it making the power im looking for. Positives are this conversions been done a million times before into s13's and parts are redily available.
So just wondering what everyone elses opinions are and/or ideas.
https://www.sau.com.au/forums/topic/267579-my-project-car/
ur budget will also contribute alot to the project as well
the engines that u have stated veray greatly in price
1uz $1700
rb20 $1000
rb25 $2000
1jz $2000
2jz $4000
the toyota prices are fairly accurate as i was recently looking for a conversion for ly ls400 and these are the prices i got.
ill be honest with u, u wont be able to do much for less than around 10 grand. half of the motors need some serious custom shit to make them fit in + the wiring will be a nightmare and add huge costs to it also.
if i were u i would put an s15 motor and s14 gearbox and it would hammer hard as
but if u have the funds then definatelty go the 1uz. that would be sick
a v8 silvia lol
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4562626
1uz $1700
rb20 $1000
rb25 $2000
1jz $2000
2jz $4000
a v8 silvia lol
oh its a project that will happen over time and i have more than enough funds to support it. Mostly I want to do the majority of the work myself for the satisfaction. Added bonuses of the 1uz are the weight in comparison to the rest of the engine I have stated, there alot lighter suprisingly. And seem to be a very nice fit into s13 enginebay, there cheap as you stated above. Supercharge maybe with ITB's i dunno.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4562680
What do you have in mind as the purpose for the car? If it involves track work then any of the engines proposed will make the car handle worse than it does stock.. If you just want a toy that is fun and a bit different then go for which ever you like/have the budget to support.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4562876
deffinetly not a track car, or else id look at an sr20. Mostly as a daily driver and for a bit of fun/project. Mostly as its something to work on myself and get some self satisfaction out of besides the few ovbious bits and pieces like wiring etc. What I will do once I get the rest of the panels and start sanding/prepping the car for spray is start a post up on progress.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4562959
Since it's going to be a daily you would want to probably look at making it legal. Engineering might be something else you're going to need to factor into the cars cost and could persuade motor choice.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4563108
I would go RB20DET or RB25DET.
I have a feeling it would be an easier conversion then fitting the Toyota engines in...
I would go RB25DET if I was doing this project.
A well balanced inline 6 with a nice over power range.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4563987
For ease of conversion and lower costs with still enough power on tap, RB25 with RB30 bottom and a GT30R off the side.
If budget isnt really too much of a conern, 2JZ with a T04Z. Stock internals you'll be up in the 400rwkw's with ease
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4564288
budget isnt really a concern. As I said the downside to rb25's is the weight of the engines. I still want to retain some form of handling and they are by far the heavier engine of the lot and will require internal work to be done sooner if i end up chaseing more power. As a 1j or 2j may be more costly to install, they have alot more room for power without cracking open the engine.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4564592
Well if budget isnt a concern, the BEST would be the 2JZ. Ive got a supra with a 2JZ, awesome motor, the motors are a lot cheaper than people think if you look around. Throw either a 35R or a TO4Z on there and the widest/most grippy tyres you can afford. Heaps of fun!
Do you really think adding 2 more cylinders will turn the car into an understeering shitbox pig?
Ive been in a few 6cyl S chassis's now and they're not utterly shit as most internet mechanics would have you believe. Of course its not as ideal as a 4cyl, but if weight is that important, change the front panels for alloy/fibreglass.
Worst case, you get the suspension setup to suit. Depending on what those specs are your tyre life could suffer.
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4566012
1jz
2jz
rb25
1uz
rb20
rb25 for sure
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4566566
If it's going to be your daily do you really want a 400rwkw 2jz monster?
lol, yes!
I plan on doing this soon, have started getting bits together, for the ease of installation the bottom end will be RB30 or RB26. About 350rwkw, GT35R, etc. Daily driven of course :)
https://www.sau.com.au/forums/topic/267579-my-project-car/#findComment-4566657
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
