they are different, hence the requirement for a spacer in the rear fork of an M35 when using the BC coilovers, as i believe they use the same rear strut for both kits. no biggie, thanks to dale who supplied some large washers to make up the gap!
No shit.I have to find out what scott got me then. Works well though..
Wicked, this opens up more options then..
Daiyama and Tanabe are a fair bit cheaper than BC, but only made for Z33
Cheaper but is the Quality as good as BC's, for $1299~ shipped, I think they have the most comfortable ride I have ever witnessed. After I tune I think I know whats next :)
setting the dampers on mine on its softest setting, it was a tiny bit firmer than stock, very nice though!
i like it a little hardcore than that, so i clicked it over four times :P
nice, the time will come when i shall invest in some BC's,
I reckon the car feels abit better when the dampers are a little higher, not rediculous though, just enough... but can understand those with wife and kids that would complaint.
ooooooook so do we agree that after market coilovers made for V35/Z33 will fit into an M35 provided a spacer is used?
seems as though mate. Iaiaiaiaiaiaians definitely gotten em in!
well, i dont have V35 coilovers in, the fronts are totally different.
i have a kit for M35 4WD, its just the rears are almost the same as a V35. DONT buy V35 coilovers and expect them to fit, unless you have a PM35 RWD
Can someone here advise if it will be all right if I purchase the lowered springs on IM only? I'm trying to find a cheap sollution instead of buying the whole kit at once.....
Has anyone done this? which springs were used?
Cheers,
Fabio
Cheers,
Fabio
Cheapest way out is an angle grinder. :devil:
My suggestion is to wait and save up for some BC's as your shocks are surely on their way out by now anyway.
If you really want to waste your cash, try King springs, they make a set for the v35/350z which should fit but may be a little low for speed humps etc, mainly due to our long wheelbase. You may be able to ask for slightly firmer rear springs.
Cheers,
Fabio
Far better to buy a full kit as the struts give the stability to your suspension (particularly regarding rebound).
Unless you want to be lower to the ground and still bounce like a yo-yo :P
Yahoo is a great place to buy used and new stuff for our M35's and Aaron and the guys at Import Monster can certainly be trusted with your purchases.
I bought my Nismo's (among many other things) through them. Easy, great service and you can see the price breakdown before purchasing :thumbsup:
I guess it's worth doing all at once.... an adjustable probably is the way to go I guess....
Thanks for your reply.
Cheers
Grinder... haha
I just bought a white Stagea like yours in Japan and it's on the boat at the moment... it has 74K genuine kms... car used to be owned by a family hopefully suspension will be tidy....
quite keen to do wheels, suspension, exhaust... but I guess i'll take it easy otherwise I'm in trouble with my wife....
You seemed one of the most experienced and knowledgeable here therefore I was wondering if you could get back to me with few answer.... Sorry it's not related to suspension...
I'm about to take my car for compliance at Northshore Prestige any advice? Should I check transmission fluid? How much am I looking at for a custom made exhaust system?
Cheers,
Fabio
Fabio, my Stagea was complied by Northshore 4 years ago and I have seen the results on a few other M35's. They do an awesome job, can't really fault them at all. Oh, and they do the cleanest job with the rear anchor/restraint points that I have seen (no leaking for reckless hole drilling).
Grinder... haha
Cheers,
Fabio
Ive heard Northshore do one of the cleanest compliance jobs, unfortunately mine wasn't done by them. Cam, I have worked out it was the silicone blocking the drain lip that caused the water ingress, all fixed. :)
Get on Import Monster and look for a cat back system, I can make a dump for around $450 but you will need to get the front pipe made up locally (unless you come to Melbourne).
All fluids are supposed to be changed at compliance, make sure whoever does it uses the Nissan matic J fluid or Nulon synthetic, you cant use dextron 3.
For suspension look closely at the BC's. Great value for money.
  • Like 1
Thanks for your prompt response.... much appreciated the info...
cheers
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
