Originally posted by Duncan
Moanie, who's "ned" :confused:
Looks like Blitz was doing fcuk all in that photo
:bahaha: it was meant to be 'end' :P
Hey Duncun! saw you on Victoria rd on sat...near the iron cove bridge...you were turning off into a side street....guess you missed the person standing at the lights jumping up and down and waving her arms around :(
  • Replies 99
Originally posted by benm
I've heard rumours about that corner Moanie, u should watch urself there !
Y'see Ben is used to girls standing by the side of the road waving their arms up and down trying to 'attract attention'.
It's not the red Skyline... it's just Ben and the girls just don't want him to be 'without company'.
So... is the back suspension on your car properly setup for umm... track days?
T.
that xr8 that did just over 200 kw was my brothers car . sorry i didn't put my car on the dyno but didn't see any point as i havn't done any work since the last dyno day here in sunny canberra. o by the way his name was simon just in case you wanted to update the standings,he really only did it to beat the hsv ,but i m not starting that argument in here.ford v's holden is old skool
Originally posted by Moanie
:bahaha: it was meant to be 'end' :rofl:
Hey moanie, god help me, that was Pete driving my car form powerplay down to scruitineering for the rally this weekend. He mentioned something about trying to set a nasho record.......
Ahh..makes sense...powerplay is just 2 secs from there...hehe...i always drool over the cars there...hehe...was almost gonna stop in on sat...but decided against...
oh...and go the holdens!!! :rofl: Whose HSV was it?!?! *drool*
I had to laugh CNG when they opened your Carbon Fibre Bonnet....
It was like Moth's to a bright Flame......
We swarmed all over your car.....
I'm glad you announced the turbo type too .... I'd say most of us had no idea it was a HKS T04E....
Oh and thank's for the ear bleeding Buster....
Man it hammered..... the ringing in my ear's has only now eased off.....
Loz
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
