Nuh dont think he can ash because even in victoria if your plates are stolen they done issue you with the same ones. They wont allow having 2 sets of the same plates floating around.
serious? fark... thats shithouse...
but then, with plates like that - gotta expect someone is gonna make attempts on em :)
Lucky he can just order another set...
Yeah!!
My plates have been stolen twice and QLD prestige plates only cost $370 Delivered to have remade and sent.
They are a lot different to the standard pressed plate as well so i would imagine normal plates be considerably less.
That is soo gay, those plates are awesome, hopefully he finds em, im sure everyone will keep a look out for those plates.
But the fact that it was ripped from the bolts suggests either that someone just wanted them to keep personally rather than put on a car, so i doubt any of us would see them again. Anyhow anyone that takes 500 bucks from you is gay too :D shouldn't need to pay someone to tell them they found your plates that were stolen off you to begin with.
Hope you can get them remade and sent out if you dont see the originals floating around. Ill keep an eye out and tell my mates too.
depends were you are
and what type of plates
if there like mine RB20TT on white and black in NSW then $90 & six weeks wait
it dosent even make sence
i only went 4 RB20TT cauz every over plate waz taken???
some people realy shoud be shot!!!!!!!!!!!!!!!
i only had them 4 A WEEK AND THAY GOT STOLEN OUT THE FRONT OF MY WORK!!!!!!!!!!!!!!!
GOOD LUCK
^^ Well there you go then
Hmm guess your right then, must only apply to standard issue plates in victoria. Must be different to were he is. Stuff paying for custom plates and they cant make you a new set if they get stolen.
  • 3 months later...
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
