Basically what the above person mentioned.....
Check condition of gear knob, steering wheel, side bolster on the drivers side seat, wear on the pedals, check alignment of km digits.
Take it for a drive, listen for any knocks in the suspension or a rough idle. Check for oil leaks etc.
Could someone please explain why it is so common for imported cars to have excessively worn (basically no leather left on them) steering wheels? Do Japanese drive with sandpaper gloves or something? Or is it from something else? Most cars you see here could have done over 200,000kms and the wheel isn't worn.
Originally posted by dan_the_man
apparently Japanese men who smoke, sit in traffic jams and pick at the steering wheel with their nails... frustration of some sort.
Thats why its only on the top half of the wheel
Well look at it like this...
If we exported our old VN Commodores and EA Falcons to Japan, what would they say about us?
The same thing we say about them!
ie. young hoon type who smoke more than just cigarettes, big type sound systems and wear on knobs, wheels and pedals from general bad driving. If you wear rings you wear out the steering wheel.
T.
I've heard that it's because a lot of Japanese are fond of the bling bling and wear lots of gold rings which may cause excessive wear on the wheel.
There are exceptions to the rule though, mine was in excellent condition when I got it, and is virtually the same now (I don't wear any rings or pick at the wheel with my fingernails).
You might be able to see some small wear on the right on mine in this pic, this is from where the previous owner attached the "overboost" button for the boost controller. I never used it so I removed it.
Japan has one of the highest % of smoking population in the world.
"I've heard that it's because a lot of Japanese are fond of the bling bling and wear lots of gold rings which may cause excessive wear on the wheel. "
False. Many men don't even wear wedding rings.
I've walked through many, many japanese car yards and have consistantly seen cars with low kms. Wound-back odos are definitely a fact of life, but I have a feeling that happens far less than people think - particularly with high-end performance cars (though I wouldn't say a GTST fits under that category).
So they're all just a bunch of neurotic steering wheel pickers then?
dunno, my s. wheel and g. knob were both fairly worn and my car only had approx. 43k km on the clock (logs to back it up). I simply replaced them with momo and feed items anyway
sweaty hands maybe? though they often claim that they don't sweat as much as gaijin...
i used to think that the condition/wear of the interior/exterior items would be a sure indication of the 'true' age of the vehicle. I remember when shopping around for a 180SX a year ago....saw one on sale for around 40-ish Kms on the odo....but the interior and engine bay condition was just shocking....dusty, faded interior panels...worn pads...etc etc...
Now with my 96 S2, it came with 36ks on the odo, immediately i thought "yeah right"....but i was amazed at the condition of the interior as well as the engine compartment....then again parts could've been replaced etc etc....so i didn't really care....besides it went really well...
Took it to 2 seperate workshops to get some servicing done and mods....and both(without me asking) commented on the immaculate condition of the under-carraige and the 'as-new' condition of the stock parts....so i dunno what to think now....
either way i'm getting one of them 'Super-Strong' timing belts done soon just to be sure.....
A real sharp shifty used car salesman will know all about winding back or replacing the speedo, and all about wear on the steering wheel, carpet, drivers seat, drivers door, and pedal pads.
What the bugger will not change though, is the brake discs. They may even have been reground by the previous owner, but they will be always be thin on a very high mileage car.
