Not sure if this has been posted before but found it the other day.....
question is..... is this to much power. would less power result in a faster lap time. this thing looks rather hard to control even on this larger track... OR do you think with a top driver (eg - Tsuchiya) this thing would be unbeatable.
let the footage and thoughts roll !!!!!!!
https://www.sau.com.au/forums/topic/269725-endless-r-r34-gtr/
the problem is the track and the driving style. of course it's going to be a bit of a handful when you are taking most corners in first or second gear! that is a pretty dinky little circuit, not really suitable for the car, and even a mild track GTR will light the tyres in first and second gear coming out of a corner....
I know its sequential box, but it still sounds like a stocker 34 box on idle, but then again the dog box i had sounded similar to the stock 34 box on idle too..
big cams and titanium exhaust by the looks on that car, hopefully the result i end up with too! sounds awesome!
Do OS Giken make a sequential box or is a OS Giken gear set in a std hsg with one of those ikea formula sequential shifters bolted on?
Does not look anywhere near as smooth as the holinger.
it's an OS88 full sequential 6 speed close ratio box. nothing like a conventional box with ikeya shifter.
OS88 box is a good thing. some people i speak to in japan rate the hollinger, some rate the OS88 or HKS sequential. almost none use the trust/quaife box.
yeah i've used an ikeya shifter. it's ok. not sure it's the best money spent and not sure it really imrpoves lap time. it does mean you wont miss gears i guess. it's also only as good as the box you sit it on top of. don't expect it to turn a standard nissan box into anything like that OS88 above... it also takes a little getting used to at first! their paddle shift set-up for standard boxes looks quite cool too. but again, not sure it's worth the dough.
the one above probably looks savage next to marks hollinger as mark is using a strain sensitve gearknob which activates the ignition cut for smooth gear shifts. not sure that the endless car has that, from the look of the vid i'd say not. they just bash it into gear.
edit: I should mention a friend in japan sent me pics of that car when it was getting built and when it was finished a year or so ago when we were just building the hi-octane R34. It was one of our benchmarks in look, and quality of finish etc. and I think we did even better. :whistling:
Hey Michael I believe from memory that the os88 sequential box is around the 12 000 000 yen mark wich is substantially cheaper than a holinger and it is also rated to 1500hp where as the holinger is only rated at 800hp. But in saying that i do believe that the os88 is more suited to drag racing rather than track use. And there is no choice of ratio's used you get the ratio that they supply and that is it. Hence Richard saying that the diff hears would need a change.
Thanks for the info Richard, i enjoy building transmissions i used assist in running a transmission section a few years ago but we mainly built power shift and some counter shaft transmissions, have done a few road rangers and alike but my experience is minimal on these smaller boxes. I have been considering attempting to build my own but i might have to try something cheaper and simpler first to see how i go.
Sorry to hi jack the thread the car is not to bad for a drag car, :whistling: .
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
