What turbo/ 's are you going to use ? Interested to know as I have similar 2.8 build being done here in Japan by HKS.
They were reccomending HKS 2830's with the V Cam and 2248/274 cam combo. Supposed to idle pretty standard but boost comes on real early and pulls all the way to top RPM..I went for drive in one of their customers gtr and was bloody impressive.
Mines at a stand still at the moment, still waiting for head to come back from the NAPREC
Edited by elrodeo666
  • Replies 103
That was supposed to be 2835 turbo's
V- Cam unpacking
I have always found the unpacking process fascinating, so I have documented it with these photos to share with everyone.
Thank goodness Benno has worked out how to install it. The instructions are entirely written in Japanese!
dont mean to sound like a retard but is the HKS vcam kit essentially the same thing as the RB25 VCT? variable cam timing?
sure the RB25 setup you can't touch / tune etc, but the same logics, that is, a variable cam timing system - cam timing that changes, with load etc
A set of off the shelf Garrett 2860R -5s will be installed.
In Cam as per V Cam Type A setup - Valve timing 90-120 degress, valve lift 8.6mm, duration IN 248
Ex Cam - 256 valve lift 8.7mm
It should be interesting how much boost these will develop in the hands of the maestro. The secret is in the rest of the package so I am led to believe. The truth will be told when I take my first test drive once its completed. Car is in the workshop atm.
You are spot on paul r33. If I put a RB25 head on a RB26 bottom end and get someone who knows how to put it together, then I will essentially get the same result without the HKS badge!
Sneak peek:
post-32660-1243148737_thumb.jpg + post-32660-1243148843_thumb.jpg + Dose of Racepace Magic
= Total Awesomeness!
I saw this beast finished @ Beno's today, when dropping mine 32 in & picking up Pete's 32.
This 34 looked very clean & crisp. Good Luck with car bud, seems u pland well & workd hard to achieve a fantastic result.
Keep us update..
:mad:
so its just the intake cam that has the VCT yeah? I would imagine this would be much more efficient than the 25 VCT as you can tune it right through the rev range not just switch it on and off
Sweet setup, so its nearly finished? make sure to post a dyno chart when its done:) will be a response monster!
I believe my car is next in line... I should have bribed Benno to drop that stroker crank into my build, you would never have known;) lol
No dry sump? :P
Dry sumps must be a NSW thing. As far as I've seen at the track, there is not one dry sumped car in Vic, however we never seem to see oil starvation blow ups either.
It sure looks sexy with the pumps and all, but is it really necessary for club cars where a well made sump does the trick?
There sure are some monster RB's in the build right now.
Glad i know of a couple that are NSW based so you Vic guys dont hog all the fun hahaha
Seriously though, great setup, looking forward to seeing the results :P
No dry sump is planned. Just a larger capacity oil sump with High performance/high flow Tomei Oil Pump. In fact the V Cam needs oil line to work properly and HKS does recommend a higher capacity Oil pump.
That does look like a fairly simple system, I guess yes the principle is exactly the same as the 25 VCT, oil supply, a solonoid to switch it on and off...this is awesome!
The thing I like most is the HKS POWER rocker cover. Its very very special, and they even give you the little red V-CAM badge!
This car will be insane...considering Aaron's 34 with the 2.8 and -5s made 350kw at 3,500 rpm? and 450 at like 7 something? (Cant remember exactly).
Built by the same genius plus the V-Cam....I really cant wait to see the graph...
Really good work on the pics Matt, its like were all opening the box ourselves! Except we dont get to touch and do other naughty things with the parts :)
I must admit Ben is like an eccentric craftsman (no offfence to him). He has good enough reputation for him to be selective with his clientele. And no he did not shake his head when I approached him with the job. Its for other reasons which will come into light in the near future.
As for turbos, I can't get hold of any Garrett-5 as they are on back order world wide. I am considering a set of HKS 2530s or Tomei ARMS B7660 now. But just for the HKS or Tomei brand will cost twice as much as the Garretts off the shelf. :P
Seeing Benno tomorrow
Dont mean to do a thread hijack
I'm in the same boat..once I made the decision to go the -5's and ordered them up, been waiting a good month or so and looks like awhile yet. Glad my head is taking forever and everything is at standstill.
If you want to spend some coin, most guys here running the V Cam go the HKS HKS 2835's with the and 248 In /274 Ex... they are beasts to drive, absolute weapons but pretty exxy.. I could get you bit of a discount thru HKS if your keen. I initially had this plan but went the -5's as was just after something near the 600-650ps margin. The HKS 2835's and V Cam would be easy 700+ps. The ones I have test driven have been 700 to 800ps..
What computer unit you going to run. Reason being there is another bloke in WA dunning Apex Pc and having major dramas. I had a talk with tuning maestros guys at HKS and they reckon anything other than Fcon Vpro and mdel before you will be pushing shit up hill..its doable but you will have a hard time trying to sort it out. Its typical HKS, all their stuff is made to run hand in hand and not with the competition.
I'm trying to suss some tuners in oz who would put up their garages for a week or 2 while my mate comes out and does some tuning but there is the whole political side with HKS to work out yet. Right now its an idea but we've put it on the table here and see what happens.
This was a GTR33 that had limeted edition V Cam
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
