Hey all,
I just got my car back from tuning a few days ago.
Its a pretty much stock r33 gtr, just with a power fc and an exhaust.
Its running 222rwkw @ 12 psi.
im getting around 420km to a tank driving sensibly and around 360 to a tank when i give her a bit of a hard time.
is this a good healthy result? power wise and economy?
what do you experts think :(
cheers!
https://www.sau.com.au/forums/topic/270342-just-got-my-car-tuned-r33-gtr/
  • Replies 75
Hey all,
what do you experts think :rolleyes:
cheers!
That sounds nice/healthy.
I get about the same as you, my mods are twin airpods, down, front pipes and high flow cat stock catback atm.
Stock +0.7 Bar (10.9 Psi) of boost.
If I really drive sensibly I can get 250kms just under half a tank, X 2 = 500kms, but I usually fill up when it hits half as half a tank last me about a week.
Plus you got an APexi Power FC which will help out with your air/fuel mixture.
hey, thanks for the info!
i've always wondered, are 32's lighter on fuel than 33's in general?
just curious!?
R32 GTR's are lighter, so there is less weight to push.
From memory I read this from some where...
R32 GTR = +0.7 (10.9 Psi) Bar Boost (Stock)
R33 GTR = +0.8 (12 Psi) Bar Boost (Stock)
R34 GTR = +0.9 (13 Psi) Bar Boost (Stock)
(I will have to check...)
So the more the R33 full boost, as apposed to the R32 full boost, the R33 will need more fuel as it is running a higher boost level.
But it's MARGINAL... So it should not make much of a difference but it will add up in the end.
hi all, thanks again for the comments and reassurance :devil:
here are some pics are requested -
apologies for the mess in the interior shot, i was sticking my turbo timer back on.
post-54322-1242660701_thumb.jpg post-54322-1242660756_thumb.jpg post-54322-1242660799_thumb.jpg
dude. that is dammmmm sexy. i love your instrument cluster ( nismo cluster ) i want that in white !!
awesome clean car.
Very tidy S3 mate, as for keeping it stock - yeah, right :(
With exhaust, front pipe, high flow panel filter in stock airbox and PowerFC my R33 just made 239RWKW, so power wise yours seems pretty much on the money.
No idea about fuel economy though, I just fill it up and go drive it some more >_<
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
