Haha yeh no problem there mate ;)
I would have thought people were referring to the actual upgrade... a de-tune was expected from Nissan anyways, probably a good 50kw down, nothing that gets factory imported in to this country comes in full spec. Its compensated for climate and harsh weather we get here as a precaution... :yes:
Really keen to hear the before number for sure, but even keener to to hear about the gain
  • Replies 96
Posted Images
Hey guys, just to shed some light on the power figures, the kW figures at the wheels of the Oz Spec GTR R35 reflect actual advertised engine kW figures so no probs there, its just that the Jap Spec cars are definitely higher & have approx 20-25kW more at the engine from the cars that we have dyno'd so far.
Obviously this could be coincidental that we happened to get a couple of really good Jap Spec cars and a couple of average Oz Spec cars on the dyno???
We will keep you updated and post the dyno figures soon!
awesome, thanks
with respect i think people are referring to this:
"After running the car on the dyno it is evident that the Oz Spec car is de-tuned compared to the Jap Spec version."
Obviously the car has been on the dyno for a baseline run and the number was apparently something of a surprise. It was brought up and people are interested, where's the problem? If it can't be revealed that's ok, bit of a tease though! :)
Hi Duncan, Yeah Jim, (CRD) the 35 & 32 are similar down the straight at E/C and most blokes are getting real excited, some standard figures would be appreciated? but make them await your forecast figures to give us more time with 32, thanks
The Beast has Woken!
Here are the results of the the HKS GT570 system we have installed on a R35.
Soon we will post pictures & a video link for all to hear the magnificent sounding BEAST!
Well done guys...top stuff.
Let me guess...the owner of this car is E.B. ?
  • 2 months later...
Hi there,
We finally got our COBB PRO TUNER SOFTWARE in, along with our customers GTR R35 for a custom reflashing of the ECU.
Results were fantastic with the car making over 380kW at all wheels which is awsome considering that we are still running on standard injectors.
The larger injectors have been ordered and with further programing we should be able to dramatically increase mid range torque going by the initial test results on the chassis dyno.
Generic & custom mapping is now available from the tuning shop that made the NISSAN GTR the cult car it is today in Australia, Croydon Racing Developments!
We will keep you posted on further developments.
Nice results...but
I cant help myself. CRD gave the GTR its cult status in Australia? :D LOL i am not sure, but based on the amount of Suzuki GTIs you used to do back in the day i will pay the fact that you made those the cult car of the early 90s :P:D
Again, good work on the results! :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
