I feel weird saying I have a bit of badge snobbery by leaning toward the Hyundai :P
Toyota FJ is basically a Prado underneath I understand, so should serve you well.
They're but in the USA? Does that explain why no oil burner donk?
hello friends,
am looking at buying a diesel tow car/4wd with a budget of 10 -> 15k. it would be towing my S14 on a car trailer.
i was leaning towards a 80's series landcruisers post 96 were the tow rating was changed - what are opinions on these?
can anyone please suggest some other options that would suit my price range?
cheers
hello friends,
cheers
Are you needing anything else from the vehicle other than towing ability?
Seating capacity, daily driver, economy requirements........ ?
not so much, mainly just towing and off road ability for some fun
half decent fuel economy would be nice but i have a daily also so not essential.
cheers
Well as soon as you say "off road ability" which I reas as "serious off-road ability" I instantly think live front axles.
So, 'Cruisers and Patrols are on the menu, wagons or utes depending on what suits. Avoid British shit but we all know that.
Don't get carried away with lifts etc, coz the higher you go and the bigger the tyres, the worse they tow.
Diesel Cruiser or Patrol, aftermarket turbo kit if it doesn't already have boost. Budget i9s the hard part.
Personally, I'd be having a crack at busting this bloke's chops, or trying to find a GU Patrol ute with 4.2 turbo.
http://www.carsales.com.au/private/details/toyota-landcruiser-1994-14020428?base=1216&vertical=Car&cr=10&eapi=2&__N=1216%201246%201252%201247%201282%204294962861%204294962570%204294680273&num=15&silo=Stock&Range=Price%3a10000%2c20000%7e0.5&sort=default
yeah 'serious off road'
wow at that link. 20k seems pretty crazy. newer versions are much cheaper here in perth >.<
not sure it would be up for the towing capacity either
pretty much what i thought - will target the cruisers and pooohtrols
cheers mang
cheers mang
New ones attract less money because they have the shitbox ZD30 in them and will blow up. If you read back I rave about my 4.5l dual fuel Pootrol quite a bit, but think it is justified, I get 18/100 driving daily, heaps cheaper to buy and run day to day than a diesel, and debatable how much more it costs towing.. The 4.8l is a heaps better motor again
8.4L/100 is good for a truck, how does it drive.
Now have a trailer for the Challenger, PI over easter is the plan. It's going well, only thing is the suspension needs tuning for Aussie roads. Thinking about getting a set of Bilsteins to improve it.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
