So my 2011 d40 navara tows great, good economy and all, but new house has a steep thin driveway i wanted the trailer loaded at the top, heat warped the dual mass flywheel doing it, lesson is dont reverse 2t up a hill slowly, you have to ride the clutch a little to control the speed and it heats up the flywheel... So its new clutch and single mass flywheel time already...
Tip from clutch guy i spoke too, reverse in 4lo even on concrete and all will be find and easier to control speed rather than having to ride clutch a tad...
$2k for new clutch flywheel fitted, bugger
That is a great old 4WD trick - to put it in Low Range whenever you are going to back a trailer up - no clutch slipping is required and you can easily move a loaded trailer into a trickey spot or up a steep driveway.
Which is why auto TDI tow trucks rule. Had a manual pathfinder, swapped for auto and would never look back. Race and rally cars are for fun so no need to stuff around with gears in the tow truck as well (despite my posts in other threads saying autos are ghey. Ignore those comments for the purpose of this argument)
Only possible if it's an old fashioned part time 4WD with manual locking hubs. It's the main thing I missed about my old Patrol.
If you have a part time 4WD (with transfer case) and auto hubs, this will put it in 4wd and you risk binding the transfer case if you're turning while reversing the trailer. D40 is in that category, so selecting 4L and reversing is not an option if you need manoeuvre the trailer at all. Unless there's a pov spec version with manual hubs?
And constant 4WD things (with center diffs) normally only go to low range with the centre diff locked. Again, this risks damaging the driveline. Low range reversing not really an option
Edited by hrd-hr30
The cruiser locks the centre diff lock when in low range... Makes it a pain in the ass! I found there is a way to disable it but i cbf...
I guess this is as good a place as any to ask...
We're contemplating an 80/100 series Landcruiser, which we'll probably keep and run into the ground. It'll do a lot of medium-distance towing (600km round trips) and eventually be a farm hauler too, but will probably be the mummy wagon from time to time. Since I'll be doing all the maintenance (and hopefully mods) myself it needs to be relatively easy and simple to work on. Is it much of a drama to work on the 4.2TD models? Also, is there any downside to the 1FZFE petrol engine other than going through fuel like there's a hole in the tank?
Wihle I'd love to go for a TB48-powered GU Patrol they're like hen's teeth over here and highly priced when they turn up.
Nothing wrong with the Toyota motors other than the petrol sixes valve stem seals.
The 100 series 4.2 turbo diesel is an absolute cracker!
This is what i want to upgrade too!
Heard first hand from a bloke who has a Toyota V8 diesel from new, fuel system failed at around 130k, cost him something like 8 to get it fixed. Toyotas are not what they used to be, particularly the diesels.
When I was working for Nissan last year I borrowed one of the STX550 Navara's to punt a car trailer around with the old GTR on it. With the 7 speed auto and the power and torque from the V6 3 litre turbo diesel it drove the same as when it was unloaded.
Now I just have to buy one dammit!
I was wondering why they only have a towing capacity of 3T compared to other cars with less NM that have 3.5T... We looked at an ST550 and it didnt look all that exciting! Would be nice to tow a nissan with a nissan though :P
  • Like 1
Towing capacity has about 13.75%(*) to do with engine power / torque and 86.25%(*) to do with vehicle mass / stability / chassis rigidity. A 430kW / Zillion NM HSV GTS has a lower towing capacity than the Navara
*Percentages for illustration only. Actual results may vary.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
