So my 2011 d40 navara tows great, good economy and all, but new house has a steep thin driveway i wanted the trailer loaded at the top, heat warped the dual mass flywheel doing it, lesson is dont reverse 2t up a hill slowly, you have to ride the clutch a little to control the speed and it heats up the flywheel... So its new clutch and single mass flywheel time already...
Tip from clutch guy i spoke too, reverse in 4lo even on concrete and all will be find and easier to control speed rather than having to ride clutch a tad...
$2k for new clutch flywheel fitted, bugger
That is a great old 4WD trick - to put it in Low Range whenever you are going to back a trailer up - no clutch slipping is required and you can easily move a loaded trailer into a trickey spot or up a steep driveway.
Which is why auto TDI tow trucks rule. Had a manual pathfinder, swapped for auto and would never look back. Race and rally cars are for fun so no need to stuff around with gears in the tow truck as well (despite my posts in other threads saying autos are ghey. Ignore those comments for the purpose of this argument)
Only possible if it's an old fashioned part time 4WD with manual locking hubs. It's the main thing I missed about my old Patrol.
If you have a part time 4WD (with transfer case) and auto hubs, this will put it in 4wd and you risk binding the transfer case if you're turning while reversing the trailer. D40 is in that category, so selecting 4L and reversing is not an option if you need manoeuvre the trailer at all. Unless there's a pov spec version with manual hubs?
And constant 4WD things (with center diffs) normally only go to low range with the centre diff locked. Again, this risks damaging the driveline. Low range reversing not really an option
Edited by hrd-hr30
The cruiser locks the centre diff lock when in low range... Makes it a pain in the ass! I found there is a way to disable it but i cbf...
I guess this is as good a place as any to ask...
We're contemplating an 80/100 series Landcruiser, which we'll probably keep and run into the ground. It'll do a lot of medium-distance towing (600km round trips) and eventually be a farm hauler too, but will probably be the mummy wagon from time to time. Since I'll be doing all the maintenance (and hopefully mods) myself it needs to be relatively easy and simple to work on. Is it much of a drama to work on the 4.2TD models? Also, is there any downside to the 1FZFE petrol engine other than going through fuel like there's a hole in the tank?
Wihle I'd love to go for a TB48-powered GU Patrol they're like hen's teeth over here and highly priced when they turn up.
Nothing wrong with the Toyota motors other than the petrol sixes valve stem seals.
The 100 series 4.2 turbo diesel is an absolute cracker!
This is what i want to upgrade too!
Heard first hand from a bloke who has a Toyota V8 diesel from new, fuel system failed at around 130k, cost him something like 8 to get it fixed. Toyotas are not what they used to be, particularly the diesels.
When I was working for Nissan last year I borrowed one of the STX550 Navara's to punt a car trailer around with the old GTR on it. With the 7 speed auto and the power and torque from the V6 3 litre turbo diesel it drove the same as when it was unloaded.
Now I just have to buy one dammit!
I was wondering why they only have a towing capacity of 3T compared to other cars with less NM that have 3.5T... We looked at an ST550 and it didnt look all that exciting! Would be nice to tow a nissan with a nissan though :P
  • Like 1
Towing capacity has about 13.75%(*) to do with engine power / torque and 86.25%(*) to do with vehicle mass / stability / chassis rigidity. A 430kW / Zillion NM HSV GTS has a lower towing capacity than the Navara
*Percentages for illustration only. Actual results may vary.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
