  • Replies 40
im not going to attemt all this by myself as i am not experianced in working on the vehicle myself. trying to elarn but yer... lol. and it doesent help when i have a hybrid pipeing systam wich pretty much wont let me access my coilpacks lol.
thanks =)
I've got almost no mechanical knowledge and i still managed to put in Splitfires and new plugs in my car. I've got a hybrid kit as well but it didn't pose any extra trouble. Hardest part is getting clear access to them, once you've got to them rest is easy. Think there are a few guides floating around on here too if you do a search.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4637537
  • 1 month later...
Provided its small, direct jobs which require little instruction (attach front bar, paint car etc) Jerry does a good job, and if he stuffs up he will fix it for free. But do note that he doesnt do mechanical or electrical anymore. He will send your car to Fast and Furious automotive for anything mechanical and will get a 3rd party electrical to do anything electrical.
But when it comes to bodykits, paint work, customising bodykits (he even makes some of his own) and anything external he is great.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4755913
  • 4 weeks later...
So in Canberra there is:
ESP
Trojan
Autotech
Ultimate Tunes
J Racing
Anywhere else? It would be good to compare the hourly rates of each place also.
I need a pair of turbos (probably -5s), them to be fitted and the car tuned.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805461
So for those of you who have seen my car :) *most of you i think* Do you think J Racing could colour match my pink and pearl?? I need to put my new front bar on my baby and I am super paranoid about getting good colour matching!! lol
:D
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805938
Jerry's shop did my front bar Repair+Paint. The shade was off somewhat so he got his guys to do it all again without any whinge by me. Second time spot on at no additional cost to me. That was my experience :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4806073
If my bar just has a simple crack in the front, where it got pushed back into the cooler by a gutter (what a meanie gutter it was! :)) and a few more minor cracks on the underside from driveways etc, would you recommend taking it to Jerry? I wasn't aware JR would be in the business of repairs, figured they only did fitting and fabrication.
what was your damage and how much did it cost you sinista? I've got my own can of paint (which doesn't quite match as the front end of my car is slightly darker than the fuel cap cover I got it matched to lol), do you think they'd use it so I could save a little? obviously I can't expect them to guarantee the paint if I supplied it, but it doesn't bother me much.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810547
My lower front bar lip was cracked all the way through 6-8inches long and a few minor abrassions from the dreaded gutters. You can't tell it was ever cracked and they also secured it all the way round properly (not zip ties). Cost to me repaired, preped, re-sprayed and fitted was $400.
JR will do what you ask for. If you want to spray it your self from pressure pack/s then I'm sure he wont have an issue. they should just do the fibre glass repairs. Thats what they do when not fitting full body kits.
Like verything else you get what you pay for and there is good n bad experiences. Even J Racing doesn't have 100% customer satisfaction. That said my experience with J Racing was good.
PS. As said earlier they dont do mechanical and will refer on :)
Edited by Sinista32
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810603
That's an acceptable price, I think I'll definitely head round there lunchtime Monday and maybe tee something up with them.
Your damage is more or less the same as mine, but yours sounds a little worse from the length of the crack lol :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810615
Got my car back with the bumper repaired from JR today, must say they did a rather acceptable job on it!
Mounted it correctly, and you can hardly tell it was repaired (though naturally if you look closely it's not 100% new looking, few imperfections but who cares)
The only downside of it was the cost, $480 removed, repaired, painted, and refitted. Though considering I walked in Monday to inquire about it and he took it in Tuesday to begin the repairs, can't complain about the turnaround :cool:
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4833972
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
