I didn't know that they came standard or an option on the M35's - I know the C34's never had them
the only thing I heard about cruise control on the M35 was that Chris Rogers was installing a aftermarket system in a M35 and needed a M35 to be a test mule
I have factory cruise and the radar sits just under the front grill. It works really well even when you are following a car and it slows down in front to a stop. The computer puts my brakes on and nearly stops the car. The only thing i hate about the inteligence is that if a car pulls in front of you your car slows down and it takes a while to pick up again depending on the distance set
Nagoya Motors had a blue RS with factory cruise....
Would have been perfect if it had been fitted on my AR-X. And because of my Momo steering wheel, I cannot use Chris' solution.. Buttons won't fit...
Need cruise... if only to improve the fuel consumption..
A mate of mine is about to buy an ARX with Cruise along with just about every other conceivable option.
Will be quite cool to play with it.
It will be interesting to see how it keeps the car at highway speed as I find that the car can be a little surgy on cruise.
When you look at the grill the radar is in the centre of the grill in shield like shape getting narrow at the bottom and is a dark colour. The Nissan badge sits on top of the radar pannel.
I have seen a few of them here but they are rare.
After doing s few stints on country highways, I decided that cruise is a good thing to have, especially when my good old 350 had cruise and it was the best device to use compared to other cars i've tried. So I take it that the Stag cruise should be cool to use with that added radar at the front to sense cars ahead.
Yes I know it doesnt look too good but shit is it useful to have sometimes.
Andy, when is your mate getting his Stag? I wouldnt mind checking out his car and all the options as I'm going to buy another one from Japan asap.
eugene the factory cruise cant be installed onto one that didnt get it from factory. which sucks.........
but i agree it would be awesome to have :D
Hey Iain yes I know you cant install it, that's why I mentioned that i'm going to look for another car in Japan and sell my one.
easy. fly me down hand $900 + plane ticekt and you'll have OEM style cruise that DOES NOT surge.
the mule car I did finalised the cruise cal for my unit and it works a treat.
you didn't mention where you were but if its in a major city there's a good chance I can send you to a shop and get it fitted.
stuff getting a OEM car with it - waste of money when you have a car already that runs fine.
Yo Chris thanks for the offer. Can u give me more info on it. The aftermarket kits I've seen around I'm not too impressed with, but if yours is good and works better, I will take you up on it. I've got a lot of time off work so can come around to you down south( I think that's where you were last time here in syd)
find the user MILLOS on here. he had one doen by me yesterday. same setup that will go into yours.
in short its a driveby wire unit spec'd by me to work with these cars. it uses the OEM V35 buttons to get the controls onthe wheel and from there looks stock.
feel wise you wont notice it kick in and it works like any other cruise int hat respect.
to date I haev done 30+ of them without hassle..
if you want real feedback on them pop a question up inthe V35 area for the NEW DBW version of cruise that I do. the last one I did was VAC based and worked well but took too much stuffing around to fit properly.
as i said I'm heading down that way debug a car in blacktown so Ican do yours then in fact I can probably do it onthe back half of that day if youare keen.
I think he will get it in about a week. Still the be confirmed but see if we can help a show once received.
Cheers
Andy
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
