Hey guys,
Thanks for the replies. They're not off the shelf replacements, I made them myself. Each "bulb" is made up of six 5mm white LEDs, in 2 strings of 3. I added a dropping resistor (68 ohm) for current limiting and a diode (IN4004) for reverse polarity and transient high voltage protection. The whole package was soldered onto a very small PCB and plugged into the original socket. The only downside is that LEDs have a much narrower light cone, so that the light doesn't look as spread out as the original bulb, but the colour is a lot nicer.
Cheers.
https://www.sau.com.au/forums/topic/27452-led-parkers/#findComment-576420
Originally posted by Henros
Hey guys,
Cheers.
To diffuse the light output of 5mm LED's you can sand down the "lens" portion of the top of the LED.
Try it out and see if it improves the light spread.
https://www.sau.com.au/forums/topic/27452-led-parkers/#findComment-576571
Here it goes guys, my first step by step guide
1. Remove the parkers from the car by disconnecting the wiring and twisting the sockets anticlockwise 90 degrees. This step is sure to be accompanied by much swearing the cutting yourself due to the awkward position and lack of clearance. Persistence is the key and may the force be with you.
2. Remove the 5W wedge lamp and measure the diameter of the socket opening (round end). I can't remeber the exact measurement but it should be around 13 to 14 mm. Cut either a blank PCB (printed circuit board) or a prototype strip board into a circle with the same diameter. You need 2 of those. The PCB approach is neater but needs etching to produce the pattern. The prototype board has pre-existing copper tracks but you're gonna have to work out the wiring pattern according to the circuit diagram yourself, but that shoudn't be hard. You can even use an insulating material without and copper tracks and just solder the component legs directly to each other. The role of the circular board, whatever you decide to use, is to provide a physical and electrical mounting platform for the electronic components. I will describe the PCB approach here.
3. The circuit diagram is given below (see LEDParkerCircuit.gif). As you can see, the LEDs are connected in a series-parallel configuration to minimise electrical dissipation. The resistor provides current limiting and the diode provides protection against reverse polarity and transient high voltages. I have used a resistor value which will drive the LEDs at 20 mA when the engine is on (13.8V). If you want to increase the brightness, you can reduce the value a bit, but I wouldn't go any lower than 51 ohms (which is 30 mA at 13.8V).
4. The PCB pattern was designed according to the circuit diagram, see diagram (LEDParkerPCB.jpg). Replicate the pattern with a permanent marker and let dry. Once dry, the PCB can be etched in either a iron III chloride or ammonium persulphate solution. The solutions are made by desolving appropriate amounts of the chemical powder in water. Read the instructions accompanying the chemicals. The ammonium persulphate solution need to be warm to work, so use hot water.
5. After etching, rinse the PCB in fresh water and clean off the permanent marker with metho or mineral turps. Rinse in water again. Drill holes in the PCB as shown in the diagram below (LEDParkerPCBDrilled.jpg).
6. Insert LEDs onto the board from the non-copper side and solder in place as shown in the diagram (LEDParkerPCBLayout.jpg). The resistor and diode are solder only at one end on the copper side. They also fuction as electrical contacts. See
diagram (LEDParkerPCBSoldered.jpg). Note that I have used 2 resistor in parallel, that's because I didn't have any 68 ohm resistors at the time.
7. Bend the leg on the other side of the resistor and diode and apply liberal amounts of solder to they fit snuggly in the socket contacts.
8. Plug the LED module into the socket and test it on the car. If the LEDs do not light up, reverse the pins and try again. Once you'll satisfied, secure the PCB to the top of the socket with a little bit of superglue. This is to make sure that it doesn't get shaken loose by vibrations. The finished product is shown in LEDParkerAssembly.jpg
9. Reinstall the parkers and wiring. Enjoy your new blueish white parkers!
Disclaimer: I take no responsiblity for anything that happens to you or your car should you give this a try.
Cheers.
https://www.sau.com.au/forums/topic/27452-led-parkers/#findComment-577362
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
