Would like to know what car you have used to win the All Stars Championship in Expert?
I have 2mill to play with an was thinking of a full tuned Mclaren F1 94'?
I tried with a full tuned 458 and came 4th.
Any suggestions?
Im using the GT500 R35 and can manage 3rd.....need maor cashola for a LMP car
yay for update. Performance Points, remote mode and better Ai is all detailed in the patch notes. but things like the new tracks (which i cant find anywhere except in the seasonals), and the fact that it tags which cars you own in the used car dealerships now, isnt mentioned at all in the notes.
but i must say its the best update yet...the AI cars arent immovable bricks, they can be bumped and actually realise your there!(to some extent)
the Eifel track is sweet, took my old FD RX7 for that race. lots fun to be had, and MONEY...money money money!!
havent tryed the remote Bspec yet. but will def come in handy on office days
Remote b-spec mode available now. Anyone given it a go?
Yes it's sick. I just came home from work and my drivers bust have been used a fair bit because they had earned me 0ver 1.8 m today alone. I will host some races tonight to return the favour though.
Can you explain how that works?
Do you just leave your PS3 on or do you manage the races on your work PC via your browser?
from what i gather, you need to hit the remote play button on GT5 then you can access via the GT site
If you want to host the races you have to leave your PS on and in server mode but thats not what I do, I just leave it switched off during the day and people on my friends list just use my drivers in their races, it only works if you have friends that host races. If you have computer access during the day you leave it on in server mode and host races as much or as little as you like.
Edited by NISMATT
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
