Would like to know what car you have used to win the All Stars Championship in Expert?
I have 2mill to play with an was thinking of a full tuned Mclaren F1 94'?
I tried with a full tuned 458 and came 4th.
Any suggestions?
Im using the GT500 R35 and can manage 3rd.....need maor cashola for a LMP car
yay for update. Performance Points, remote mode and better Ai is all detailed in the patch notes. but things like the new tracks (which i cant find anywhere except in the seasonals), and the fact that it tags which cars you own in the used car dealerships now, isnt mentioned at all in the notes.
but i must say its the best update yet...the AI cars arent immovable bricks, they can be bumped and actually realise your there!(to some extent)
the Eifel track is sweet, took my old FD RX7 for that race. lots fun to be had, and MONEY...money money money!!
havent tryed the remote Bspec yet. but will def come in handy on office days
Remote b-spec mode available now. Anyone given it a go?
Yes it's sick. I just came home from work and my drivers bust have been used a fair bit because they had earned me 0ver 1.8 m today alone. I will host some races tonight to return the favour though.
Can you explain how that works?
Do you just leave your PS3 on or do you manage the races on your work PC via your browser?
from what i gather, you need to hit the remote play button on GT5 then you can access via the GT site
If you want to host the races you have to leave your PS on and in server mode but thats not what I do, I just leave it switched off during the day and people on my friends list just use my drivers in their races, it only works if you have friends that host races. If you have computer access during the day you leave it on in server mode and host races as much or as little as you like.
Edited by NISMATT
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
