Oh whoops... LOL, ignore me... Brainfart moment... :P
I still expect a 3RD gear limiter bashing skid at Texi...
will give it the beans repeatedly, disconnecting the entire exhaust from the headers doesn't count as a screamer pipe right?
by the way beaker I bought a "92" vh45 ecu so i can nisstune. but it won't arrive in time :mad: . and what do you want in your package I'm sending?
got a new three core, triple pass, crossflow, copper radiator and new fan mounts that should keep it cooler. the radiator hoses are no longer 5mm away from the alternator. yay.
will have to test it at texi. pics to come.
  • 2 months later...
long time no post...well here's whats new, nothing other than finally got a nistune from unique autosports. the result?
30 kw gain at wheels. something tells me nissan undertuned these alittle.
  • 3 weeks later...
is it bad that the 79 two two door corolla i bought off a work mate had 30 degrees timing when GTRsean and I did a quick tune up today? althrough it does explain the noises it was making.......and why it looks like it head gasket is on the way out.
somehow i managed to be talked into a twin side draft weber manifold and carbies, and the plan is to put the biggest cam the stock rockers will allow. who knew spool made forged rods for them. it will sound wicked, weather it goes anywhere in hurry is up to debate. it was supposed to be a daily, so much for that idea.
It's a 'cool' daily!
So another engine I will be doing.
It will have the following:
.5mm over pistons
spool h beam rods
4K block decked, bored and honed
crank balanced
flywheel lightened
sump modified
oil pump shimmed
3K recoed head with 4K style stem seals
some sort of solid regrind cam with 260-270deg and .400" lift
port match and cleanup.
rollmaster double row timing chain
4-2-1 headers
redline dual side draft carby setup
electronic dizzy
I think that is it....
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
