  • 6 months later...
Just a bit of info for those who want to do this.
The front diff in a GTR or GTS4 is an r180 short nose. This is the same diff as many nissans incuding n/a s13's, terrano front, pathfinder front, navara front, pulsar gtir rear to name a few. They aren't always r180's so check first as some are r200 depending on model etc.
I have not done this and won't be as I don't have a 4wd nissan. But in theory you should be able to use the insides from any short nose r180 in your sump. This will make matching ratios easier and open up more available ratios.
An exampe would be using the insides (crown wheel and pinion) from a mid '80's Navara, this is an r180. You could then use the insides from an r200 from the front of a terrano for the rear. Giving you a 4.6 ratio. These 4wd's have a number of ratio's and a number of diff combos. Ratios are 4.3, 4.6 and 4.8 but there may be others too. Navara and Terrano/Pathfinder front diffs can be r180's or r200's.
  • 3 weeks later...
just to clarify that.....workshop manual calls it an F160 not F180. From that I assume it is a 160 size not 180. I'm not sure either way, that's just what the manual calls it.
yeah like the d-man said to the best of my knowledge the front is a F160 not a F180. F being front and R being rear incase anyone is wondering why there are R200, R180 etc. front GTR diffs are tiny.
it's still worth looking into though if there are other 160 diffs out there but you need to figure out for sure if there are any differences between the F and the R models. I assume crown wheel is the same but the pinnion shaft could be very different.
Like I said I have not done it and never will, but I have always been told the front diff was an R180 in the GTR and GTS4. I have seen references to the F160 which does put some doubt over it.
If someone has an R180 and a front sump from a 4wd skyline measure them both. That will clear it up.
I have never seen or heard of any short nose R160 diff though, so if it is in fact an R160 there would possibly be no other ratios available.
I doubt that an entirely new diff type was designed and built for only 1 car with only 2 ratios. So I would assume that if it is in fact a 160 there should be other short nose 160's found in something, somewhere.
Long nose 160's and 180's have been around for more than 40 years. They are found in Nissans and Subarus. They are largely interchangeable with minor differences that can be overcome. Short nose 180's and 200's have been around for 25 years plus too. Most of the minor differences can be overcome also.
These diffs are made by Hitachi not Nissan, so they are possibly found in other makes.
Short nose 160's would have to be available from something else, imo. I could be wrong though.
  • 1 year later...
Bump :)
Ok, Rb26 is going into my GTs4, so ive already got the gear ratio you are all talking about.
Would there be any implications leaving it as is?
And is this added aceleration not practial for street driving, OR its not that much of a differance.
Surely i must need to change some parts of the Drive train to suit the 26 going in.
  On 07/02/2012 at 4:48 AM, sydking said:
Bump :)
Dont change anything, 4.3s are perfect
i have a set of front and rear crown wheels and pinions sitting at home, still tossing up whether to go to the trouble of getting it installed, around 1k mark if i recall correctly
car is mainly used for short drives and not much highway cruising unless going inter-state which will be interesting with higher revs
26 does lack below 4k, so it should liven things up
@dean - are you using the 4.375 diffs in your drag clip at WSID?
  • 1 year later...
  On 25/12/2013 at 2:36 AM, Daz said:
How much better is acceleration down low?
acceleration will improve down low, by how much is all a matter of personal opinion, some will say it so a lot better and others will say a little bit
  • 3 years later...
Ok i'm resurrecting an old thread instead of starting a new one. I have a R34GT-4 manual, it comes with RC 4.3. I'm planning on getting a 33GTR gearbox series 3 as it is stronger. Are there any issues with using a GTR gearbox and the 4.3 ratio?
no, there is not. gearbox and diff choices are not linked. plus, r32 gts4 came exactly that way from the factory (4.4s and gtr box that is). I bet r33 gts4 is the same from factory as well
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
