Hi everyone,
After recently purchasing my '96 R33 with a 3" Turbo back exhaust, boxed POD, solenoid boost mod (7psi) stock SMIC and Turbo I'm concerned that I should get the car Dyno tuned. With these mods would it be wise to get the AFR's checked and a general tune done? or would it be a waste with only minor mods. Could anyone recommened a reputable workshop to go to on the Gold Coast ?
...Last thing I need is for something to go Bang!
Cheers.
https://www.sau.com.au/forums/topic/278025-dyno-tuning/
Is it running the standard ECU or an aftermarket one?
As above, there's no real way to tune the stock ECU - plus it should be fine with those pretty common mods.
If it's aftermarket, alot have hand controllers which you can check knock readings and other info
Edited by mr_scary
https://www.sau.com.au/forums/topic/278025-dyno-tuning/#findComment-4699529
Hi everyone,
Cheers.
a dyno is never a bad idea if you have the cash as it can give the mechanic and indicator if things are on there way out, eg fuel pump, blocked exhaust etc..
https://www.sau.com.au/forums/topic/278025-dyno-tuning/#findComment-4700054
Thanks Fellas,
It is running the stock ECU no other management in place, and it runs without any issues. So a dyno would only be good to show numbers and look at the AFR's but there would be nothing that could be done as far as "tuning" or fixing the AFR's.
Puts my mind at ease about that issue then.
Cheers.
https://www.sau.com.au/forums/topic/278025-dyno-tuning/#findComment-4700338
get a aftermarket stoichemeter (i cant spell it can you) mounted to an exhaust o2 sensor that will give good indication on how its going during driving im going to put one in my car, hooked up through the e11v2 though. your car would/should be fine but have terible fuel economy tho
https://www.sau.com.au/forums/topic/278025-dyno-tuning/#findComment-4700466
go call Toshi, spend that O2 Wideband money on a remap that's actually worth something!
thats the shot i was just thinking for piece of mind for him. but if more mods are on the way than dont bother go get a ecu best thing i ever did aside from a turbo.
https://www.sau.com.au/forums/topic/278025-dyno-tuning/#findComment-4700835
  • 3 weeks later...
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
