By smooth i mean it doesnt look like it will take a finger off if you touched an edge...but you did just say you have been playing with it for a while....im just wonding the best way to cut and bend it to shape.
i do alot of work with 2mm and 3mm aluminium... i use a bandsaw to cut out most shapes, a die grinder to smooth the edges... than a deburring tool to take the corners off... they are the best things ever!!!
bout $20 and they'll last for ever.
there are double edged ones that do both sides in one go... but they are double the price.
give me 30k and ill have one built in under 6 months.
you realy want the series 2 because thats when you learn from mistakes and have already fixed all the dud ideas.
But bens is a series 2 for me as a lot of RnD of ideas has been done to my car.
funnily enough the targa car i looked after 2 years ago is for sale and its 15K and about half way developed. Bilstines haltech seats cage big brakes light wheels. just needs some of the finer things done.
Are you not better off putting the ECU on the transmission tunnel so it isnt getting kicked?
Any info on the one for sale for 15k?
At 30k i think they still represent decent value, provided its registered. I have alwasy joked with mates that if i had a clue how to i would make a one make R32 GTSt series...It would be a blast! :cool: But half the fun with this sort of car is really the build, doing things, everything just how you like it.
By the time the Nav foot rest is made it shouldn't be an issue, also with the sea so far back it's less likely to be kicked.
I've made sure i've kept paying the rego on mine, cbf putting it over the pits.
The 15k gtst is black, std body kit but with gtr alloy bonnet+grill. R32 GTR rims+brakes. Cage, extingisher, isolation switch..ect. Pretty sure it's got 2 sparco seats and harnesses. 3" exhaust and dump, Haltech E11v2
Edited by sav man
At 30k i think they still represent decent value, provided its registered. I have alwasy joked with mates that if i had a clue how to i would make a one make R32 GTSt series...It would be a blast! :P But half the fun with this sort of car is really the build, doing things, everything just how you like it.
after having worked on plenty of race cars with electrical dramas you get over trying to bend around roll cages so im putting it all in the one spot.
this was all designed with a specially built foot rest in mind.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
