"I'll be converting the Crownie boxes to Alloy soon"
I'd love to see that magic trick... actually I'd like to see that magic trick in reverse! ha ha ha Alloy is cheaper than beer...
I cant wait to see the intake... If it works out well, I'm totally going to plagerise... ha ha
J.
  • 3 weeks later...
and in other news damo has been seen in the bushes around primary schools.
I've had a paint sceme in mind for a while now... and it's not painted like an animal, cars painted like animals look stupid, dad proved that.
Aw come on ben, not even something like this?
It's hard to get motivated when it's cold. I measured the suspension up today. Rear is easy to get good travel on. The front doesn't have alot of room for travel, you can only get about 60mm of travel at 345mm ride hight before the upper arm goes through the top of the tower. I'll reserch and play round with the ride hights on paper before i order the shocks
  • 4 weeks later...
Now got job security, so it's back into the car.
I've ordered my air filters for the airbox (2x Merc 600SL), and a 044 to pump E85 goodness around.
Damo wired in the ABS this weekend
I got 3/4 of a alloy donut and started my intercooler piping on the
It's almost ready to weld, I didn't take pics of the last section, but it just needs the ends tidied up, then off to the welder.
Also got the seat mounted
ben beat me to the pics but i thought id add some more pics to assist with other people wiring cars.
I use deutsch plugs for most of the bits that need plugs. these are by far the best plug you can buy. weather proof and higher current carrying capabilities than other similar sized plugs.
this is how they go together as such. this example is a plug for the ABS wheel sensor. the wire is 16gauge Mill spec is in PVC sleving which is my profered looming material. it makes the nicest neatest job of any loom but is a pain in the ass to do and probably adds 50% more time to any job.
next ois what i started with regarding all the ABS wiring
this shot shows that there is 2 looms mearging into one. a pice of heat-shrink is then slid over the top and once the 3 bits of PVC sleving are pulled into one the heat-shrink is then heated forming a seal between them all. On engine looms i use doubble walled heat-shrink that has a glue inside of it. when heated the glue goes runny and the heat-shrink pulls tight making some of the glue ooze out the end. this give an almost water tight seal and prevents the PVC sleving from pulling apart over time.
ill get a few more pics in the next week or so of the wiring into the switch pannel and fuse boxes.
I made the turbo side piping today. it's almost ready to weld up, but the pipe that damo supplied wasn't long enough...apparently this is a normal occerence. Another 50mm or so of pipe should fix it.
Got some sensors for the Haltech (oil temp, oil pressure, fuel pressure, exhaust temp)
Air box MKII with one of two filters in. pretty much a copy of the GMS one. Need to get some alloy and make it now, and then design the top 1/2.
Got the intercooler piping ready to weld today. Took ages to file all the joins so there wasn't any gaps... welder says it makes his life much easier.
I got a surge tank during the week too
  • 3 weeks later...
I got some more work done on the weekend
I cut the airbox out, and bent it up ready to weld.
I installed the Aero catches. They are are pain in the arse to install, but it's worth it when there in.
Also installed the belts, and finished suiding the interior
I got a heap of speedflow fittings for the surgetank setup.
I'm putting bulkhead connectors in the floor or the boot, will make it neat, and i won't have to worry about hoses rubbing on the hole in the floor
I'll get some hose tomorrow now i know the lengths, and then the setup will be done
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
