I plan on buying a new ecu in the coming weeks and I need a little help deciding which way to go. The car is an R32 with RB20DET and i've just installed a larger turbo, new manifold, external gate, cams and ajustable gears, ebc and a few other things.
I'd been planning for a while to go with the Nistune, until i went and spoke to the only local guy that does dyno tuning. (I'm out in the sticks). He's never had any experience with the Nistune, but he's a Vipec dealer and has done a few of them in skylines now.
So what I'd like to know, is whether either of the ecu's have any specific advantages? I do like the advantage of my car being tuned locally by a guy with a bit of experience on similar setups, but I also like the price of the Nistune.
https://www.sau.com.au/forums/topic/278238-nistune-vs-vipec/
  • Replies 67
Yes the Vipec is a very decent ecu. You should go with it. However your tuner should also be able to tune a Nistune.
The vipec cannot be compared to the Nistune because they are totally difference ecu's. You can compare a power fc and a nistune like you can compare a Vipec & Motec.
They are totally different. one does the job and works okay, the other does the job and can make you breakfast.
If you go down the vipec route, you can pull out your ebc and use the vipec to control boost for just a added $130 part so you can get the vipec for a bit cheaper and have decent boost control as well.
for the price you can't beat nistune. it gives you all the features you need as far as being able to change injector size, afm and do full adjustment of ignition and fuel maps. and most of all, full installed and tuned it will probably cost a lot less than just buying the vipec ecu, which would then leave money in your pocket for other mods
There's one tuner in town and he does vipec. He's done a few skylines and some silvias and supras with vipecs now. His main clientel is v8's but he seems to be a decent tuner.
Other than that its a 5 hour drive to Sydney or 4 hours to Canberra.
Nope. I don't really mind towing the car to be tuned if i have to, but thats basically gonna add a few hundred bucks to the cost, and i still wouldn't have local support if something were to go wrong.
Vipec is starting to look like an attractive option! :laugh:
by the sounds of it vipec is the most viable option.. after you take in costs of towing etc if something goes wrong and so on.. might be a better to have a higher initial outlay of $$$ to save furhter $$ in the future "incase" something goes wrong
have you asked your tuner about power fc ?whats your plans with the car & whats the mod list, if its just basic upgrades, there is no need to go vipec.
Listed most of the mods in the first post. Its nothing crazy, but its further than the basic upgrades most people do. The turbo is a HKS T300s but i will most likely change that fairly soon anyway to something a bit newer and slightly more responsive. :pirate:
Thats pretty much the same train of thought i'm having.
in your situation with the distance i would go with what the tuner advises.
but i am looking at getting a Nistune soon, basically because my car is just a streeter, my tuner does both. and obviously i am gonna go the cheaper option because all i need is to maybe have the timing and fuel maps changed, and possibly allow for larger injectors and the Nistune will do that.
but i have heard great things about the Vipec, but i think $14k is enough to spend on a car in 8 months!
time to start holding onto my money
brez
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
