  • 4 weeks later...
Hi to all
Another update for you's, so far this month we have managed to order all the remaining bits we need to finish the interior with. Starting work on the carbon interior in the next few weeks. Rollcage is completed and only underneath the car needs tac welding.
A Quick list of parts on the way:
OKUYAMA Carbing Pedal Set
OKUYAMA Carbing Driver Foot Rest
Superior Auto Creative Carbon-Look Shift Boot
Superior Auto Creative Carbon-Look Center Console Cover
Superior Auto Creative Black Carbon Room Mirror Slim
Superior Front Door Panel Kit BNR32 R32 Black Carbon and Perforated Black
Works Bell Rapfix Campaign Kit (Limited)
Superior Auto Creative Carbon-Look Side-Brake Boot and Grip Cover Set
Sun Line Racing Steering Adapter
Cusco Adjustable Rear Upper Arm Links
Cusco Adjustable Rear Upper Arms
ARC Columnar Type Mirror Finish Titan Shift Knob with ARC Logo
Trust Greddy Tie Rod Angle Adjuster Tie Rod
OKUYAMA Carbing Passenger Plate
TAKATA Crotch Strap for 6-Point Conversion
RAYS Volk Racing Duralumin Lock Nut Set Red
Bride Zeta III Low Max Seats x2
Takata 4 Point Harness x2
UAS Front Top Camber Arms
UAS Diff Bushes
UAS Rear Subframe Bushes
UAS Rear Subframe Spacers
Plus many more things!!!
This is looking like its going to be awesome when its done. Nice choice on all the parts.
Got any photos showing the bulk of the Roll cage setup? And are the diffusers installed yet? If so i'd love to see how they ended up.
Cant wait to see more.
Luke
  • 1 month later...
With all do respect.Where do u get ur money from its taken me 3 yrs of hard work n doin it all myself n mine will only have round 400kws at the when its tuned i respect u boys but im strugglin to get mine to 400kws.
I think it comes down to sacrifice more than anything, i give up a lot of things to do these mods and work hard, plus its not just an individual project either, the costs are split evenly between me and dad so that helps. Also if you do the majority of the work yourself, you can save thousand $$$$, i would hate to know how much it would have cost to do that carbon dash by a workshop.
Update pics coming soon, we have nearly all the parts collected in a room and going to pick up the engine & gearbox in a few weeks, can't wait so excited.
Heres a quick peek at the dash!!
Hello everyone, just an update on the car. Went down to Godzilla Motorsport in Brisbane to pick up our Engine from Mark. Very happy with it, i have some pictures and some specs on the internals.
JUN 2.7 Stroker
JUN 295 degree Cams
Oversized Valvesm, all head gear is Tomei
Stage 3 Port Job,
NPC Twin plate Clutch
ATI Harmonic Balancer
Custom Dry Sump Setup
ARE 150mm Intercooler
Hypertune Plenum and Throttle body.
PPG Dog Box With the works
+ much more
wait on...just looked at the pics.
does that say T62 or 51? hard to see in the shots
its a 62.
Jun do not produce a 295 deg camshaft off the shelf...is it a special order custon grind?
What retainers are you using?
-Turbo is a HKS T62R
-Yes Jun do make a Custom 295 Cam, they cost a fair bit.
-The Retainers are Tomei as the springs are Tomei Type C
-The dash is a standard dash with carbon overlay.
Yeah you would be correct, that is Marks old intercooler, it flows 5 degrees cooler than the trust drag cooler and has made up to 1400hp with so its well and truly up to the task.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
