OK to start with here are my upgrades before the Piggyback.....and also a big thanks to the all guy's at Envy imports for putting up with me today.
Powerduct(lol)
Air Fliter Element
Highflow GT30/71 with Garrett BB set
Dump pipe
Manual bleed valve
Standard tune is shown in Green.....the Standard ECU was taking over the piggyback at 5,750rpm.....hence the abrupt end at 164KW's....if it ran all the way to 6,500rpm's it would probably go to 170kw's.
Dyno tune is in Red. PSI has been lifted to 18psi but still bleeds off to 15psi. Response has only been shortened slightly out of the hole. Power is delivered a bit smoother. The biggest problem I had was how much power was lost through the standard intercooler after a run(approx 20-25kw's). The other small problem was wheel diameter.....the non AR-X's will always make more power because of this. Fuel economy is awesome... normally I get in between 5.8 to 6.2....a 50km run in peak hour saw 8.8 and that was with a couple of squirts. Oh and no problems at all with fuel.
So upgrade advice before tune with the mods above.....a good sized intercooler(does not need to be huge though) and a good electronic boost controller and smaller diameter wheels.....then you may see 210 to 220KW's everytime
  • Replies 74
nice!
after going for a drive in Dannys the other day i cant wait to get stuck into modifying the m35.
hows yours going with the ecu and transmission?
i think you've confused me about the "the Standard ECU was taking over the piggyback at 5,750rpm" bit..
nice!
Transmission is fine......just gotta make sure I put in the right fluid in future though :)
Don't worry...I am just as confused as well!....but thats what I was told.......we never did another run with the standard ECU settings so this is the only one I could show and give you a ruff idea of where we came from.
Edited by Jetwreck
So you hit your target of 200awkw then (or am I reading it wrong?).
If so... Very nice mate! Well done!! I guess the turbo makes all the difference... who would've thought?
Already have a custom FMIC template designed by PWR which will suite the M35's quite nicely I think... but at $850, it won't be going in any time soon. :)
Again, great to see your results... No us high flowers have something to aim for :)
I had a similar problem with the Emanage, the ecu would kill power early if something was out. It may have been the airflow meter?
So when are you getting the boost controller...:)
Must be quick now, how is the gearbox taking the power?
So when are you getting the boost controller...:(
Boost controller will be a while.....and the gearbox should hold for a good amount of time I hope.....if I buy anything else it will be an intercooler(sway bars and Nismo stickers on the way)
My problem at the moment is that my wife has no idea that I have received and already spent my tax return.....I am so dead when she finds out how much I got back :) !!!!!!.....whats the worst she can do?......take the sex that I am not already getting off me?????.......or then again she might sit me down and make me listen to her :)
Edited by Jetwreck
I'd say f**k your wife, it's your money after all. Well that's what I said to my bitch at least.
Gold!!!!! :) ....does your wife get on these forums much??? :)
PS. 5 minutes away from leaving work from my first real squirt with no traffic.
Edited by Jetwreck
lol craig let us know how it goes :)
sorry no luck....bugger bugger bugger.......followed all the way down Beecroft RD by police only to be pulled over at Pennant Hills shops and breath tested.....it's a conspiracy!!!!
Dammnnnn
im really REALLY jealous now. i want to break my turbo and install a hiflow and be forced to put the emanage on lol
Me too - despite the expense, I'm kinda *hoping* for a reason to install an HKS GT-RS on my s1 C34, then turn it up to about 15psi.
It's already got around 167rwkW on 7psi and 184rwkW on 10psi, so 200 at ALL wheels shouldn't be too far off!
Mods so far:
- Walbro fuel pump;
- GReddy FMIC;
- APEXi PowerFC;
- GReddy Profec-B Spec II boost controller;
- Bell-mouth front/dump pipe
- high-flow catalytic converter
- 3" exhaust
She was prolly interstate. If she really finds out you will be intestate. :)
My problem at the moment is that my wife has no idea that I have received and already spent my tax return.....I am so dead when she finds out how much I got back ;) !!!!!!.....whats the worst she can do?......take the sex that I am not already getting off me?????.......or then again she might sit me down and make me listen to her :)
Which intercooler are you looking at? Full kit or custom unit??
The worst she could do is have her mother move in for "moral support".
1. Indeed. Isn't that part of the deal?
2. Yes. Yes it is.
3. In those words? Suuuuure.
My problem at the moment is that my wife has no idea that I have received and already spent my tax return.....I am so dead when she finds out how much I got back :) !!!!!!.....whats the worst she can do?......take the sex that I am not already getting off me?????.......or then again she might sit me down and make me listen to her :P
Haha just tell her you cant multi task are trying to breathe, cant listen and breathe at the same time now can we! haha
hhhhhmmmmmm!!!!
Wife just found out the I have received and already spent my tax return...........there was a very long pause on the phone followed by " I am to pissed off to talk to you right now.....we will chat when I get home"
Options guys.....HELP!!!!!!
Option one: Get drunk before I get home!
Option two: Don't go home
Option three: Flowers and chocolate
Option four: Find new wife
HELP.....please!!!!! :P
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
