I should have gone E-Manage and don't listen to sales bullshit again!!!
All else fails I will sell the Haltech or burn it.
Well the Haltech option is "off" my list of things to do. .
  • Replies 74
Fcon fz ftw!
but it appears they also use the ksrom like what Scott wants to do.. (i always wondered why they used two computers to run the car properly.)
thanks for clearing that up
What conclusions have you come to Craig?
I have issues with my ecu also as the throttle lag is bloody dangerous. Im hoping to find a spare ecu in japan and ship it to KSrom for a chip. From what ive read they have fixed the lag and im guessing the airflow r&r issue. As they are so cheap, they are possibly the best option if you already have a copgyback,(cant write p*ig? totalitarian website developers!) at least untill someone here cracks the ecu.
There are quite a few companies in Japan that do remaps/custom maps.
Yes KS seem to be the cheapest, but there is also Nismo, TEPS and "G-Zone" that spring to mind immediately although I cannot recall the others at this moment.
They ALL get rid of the 25% throttle <2800rpm among other things.
1. Checked with the dyno guy to see that he had clamped the voltage on the signal from the airflow meter. - Done
2. Checked this is even worth going ahead with by doing a long trip to see wether fuel consumption was better - Done
3. Have tried dropping the boost all the way back to 7PSI.....still has the same problem just with less power. - Done
4. Cleaned airflow meter, throttle body and fliter - Done
5. Need to find someone to make up a bigger airflow meter unit to reduce the voltage and see wether that work....will have to go back on the dyno though.
6. Go down to VIC one day and see wether Cihan can fix.
8. Suggestions ...... I will try anything
Suggestion #1 - Get a decent tuner for the Haltech. I have heard that JEM and Autotech are pretty good. Do CRD tune Haltech's?
Suggestion #2 - If none of these guys can fix your tune... rip the f**kin' thing out and get either an eManage (road trip down here for tune) or Fcon V and get it tuned in Sydney.
If you decide to go with #2, I would look into the FCON first, although both Cihan (eTuner) and Trent (Status Tuning) are damn good tuners and probably worth the 8hr drive.
Edited by iamhe77
Any aftermarket ecu should be able to give you a good tune. The difference between them will be things like ease of use, fineness of adjustment (number of mapping points) computing power, useful life etc. A grunty top shelf ecu will be able to give a super tune - any ecu should be able to provide an adequate tune. If its giving you a crap tune then blame the tuner - in other words find another one. He should be able to make it run properly and tell you if anything is needed to make it run better - e.g. new afm, bigger injectors.
+1
hell, once mine is tuned next friday on the dyno (AEM F/IC-8 & S15 injectors) I'll be toying with the tune myself, laptop
will fit a lambda sensor + guage, and road tune to buggery
You guys know this how? Ive had my car on the dyno for close to 6 hours and only got it partially tuned. The M35 ecu is a lot more complex than you think, and since it controls the throttle, it has ultimate control, even though the Emanage controls injectors and spark.
If its so easy, why hasnt it been done yet?
its because its a copgy-back and they are never as good as a full remap. i THINK with a ksrom,gzone blah blah + emanage or a decent copgy back will be the best IMO.
well, frankly, from ALL research, the AEM F/IC-8 is the best copgyback you can possibly buy, better than the emanage ultimate simply thru the sheer size of the tune scope.
ie 3 different overseeing controls, 22x17 pc mapping x 3, for air:fuel, ign.timing & injector duty.
get a remapped ecu and add in the F/IC-8 or a Emanage Ultimate (same price, emanage is widely known, but the f/ic seems pretty awesome - looks easy enough to self tune with the AEM Wideband kit)
and you'll be laughing !
currently with the remap S1 c34 + safc/sitc got 240rwkw, not a bad tune at all... but with the remap s1 c34 + f/ic-8 copgyback + s15 injectors I expect a much better result.
throw on a wideband kit, save the logs of your drive, and tune to your hearts content :(
Yerrp remap for sure! no need to have all this other copgy back business going on.
if my gtr's motor wasnt near completion i'd buy that m35 tomorrow at pickles. and go thru the process of doing it..
i think i'm about to get buttt raped ;)
Agreed... IF you live in Sydney... and IF you are not modding after the remap!
(unless back and forth interstate trips sound enjoyable)
I wouldnt mind if the price was right. I would still run the emanage for fuel adjustment and multiple maps. Of course I dont think they were looking at the throttle issue were they?
Sounds like the best setup for we "Mexican's"
Don't think is was well known then... but I am sure SAS will be made aware of it.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
