Ive read through endless pages of dyno graphs and comparisons, ive even tried a few combos my self. but im after peoples recommendations as to what would be a good, over the counter purchase to put on my RB25.
I want around 270-280 with awesome response, with the potential to go to 300 ish. Turbo will be in a high mount application and more then likely externally gated.
i have previously run a gcg 3071R with .71 avo rear housing in the low mount postition internally gated and made 280 rwkw with cams and gears. wasnt a bad turbo at all. but i still felt it was a bit of a compromise being internally gated as well. boost control was an issue with this set up.
so yeah... post some suggestions people.
Cheers
Simon
find out what troy (roy) uses on his rb20 and run the same setup on your rb25det
from memory its a td06 from a GTR twin kit run in single form on a proper manifold, external gate
its here
http://www.skylinesaustralia.com/forums/Rb...o-t103095.html#
td06 20g-8cm2 rear housing
with a proper setup
yeah i'd love a TD06 20g, one of my mate has one on his 25 and makes 317 rwkw on 17 psi. awesome response too. however at 4K for the kit its a little out of reach.
after a garret option which would be cheaper yet still effective
You could either wring the neck of a GT3071 (with a 0.82 rear housing) or GT3076 or perhaps something in between like discopotato 03 just ordered ie 52 trim 76mm.
If you have a split manifold you could order a divided housing from ATP which might improve response slightly and would suit any of these options.
For about 280rwkws with fast response you can try a 52T 76mm comp on a GT30 Turbine in BB assemble using .63 rear housing. Or .58 rear housing which would definitely increase response shaving off about 20KWs top end power. You can also replace the standard .50 To4E compressor with a .60 T04B comp. Which can also increase turbo response.
have thought about tuning for E85 but availabilty issues is a concern for me as sometimes its not even for sale in SA. that and the fact for 300 rwkw i'd need 740cc injectors or bigger!
limpus: the 3037 pro s would be my ideal choice for a turbo i reckon. how much you asking?
I was thinking about this last night, 4k for the td-06 kit seems cheap when you consider what it comes with compared to a custom garrett setup.
this is a rough guide, for what I would do with a garrett setup, obvioulsy cheaper if you buy a china minifold.
decent manifold - $1200
turbo - $2000
wastegate - $500
oil and water lines - $300?
Custom Dump - $250-300 in mild steel
intake pipe- anywhere from $10 to 200
Mind you, if you can get a td-06 kit for 4k please let me know where lol
yeah thats the thing tho, exhaust manifold, dump, intake and oil and water lines i do not need to factor into cost as i'll be doing them all myself. So just need turbo and gate really.
that RX6 kit looks insane! lol
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
