i searched this but didnt get any results, so sorry if its already been covered
i want to remove those ugly rotor gaurds and was wondering if anyone has done this b4 and knows whats involved, i cant find any bolts on the backside of the gaurds and am thinking they might be spot welded on on the rotor side of the gaurd???
thanks for any help you can give!
https://www.sau.com.au/forums/topic/285617-r34-disc-rotor-gaurd-removal/
Remove the caliper and then remove the rotor. You will then have full access to the stone guard... you cant slide it off hence you need to hack it off.
Use either tip snips, an angle grinder or a combination of the two :D
cool, should make a prety tidy job of it, thanks guys
Dont do the irreversible.
Think long and hard when it comes to modifications that are hard to undo.
There is no need to cut anything. Ive only removed the fronts before. Not sure about the rears. But this involved removing the wheel, caliper, rotor, dust cap for the hub, split pin, hud nut, then hub. The hub nut on my car was 30mm and should not be on so tight that you break 2 breaker bars getting it off. After you remove this the rotor dust shield slides off. Sometimes with a little force needed.
Be careful when taking the hub off not to lose anything (ie. bearings and washer) and make sure you put everything back on in the right order. A new split pin must be installed to prevent the hub nut coming off.
I take no responsibility for any damage or misfortune that happens to you/anyone or your/anyones car during or after the process.
If your still unsure about the whole process get a qualified mechanic to do it for you.
I don't think hub needs to come off - although if you want them out in one piece, calipers and rotors should come out (or temporarily have them out of the way), which is no big deal.
I think they are interference fit to hub as there is nothing else holding them in place.
It's always nice to have things out in one piece and in serviceable condition, in this case a pair of tin snips would be the best way to go.
ceffy is talking about a31/s13 style fronts where you can easily remove the spindle to get the backing plate off in one piece.
Unfortunately the front end of a skyline is completely different and short of having your front stub axle and bearings pressed out and back in you are stuck with cutting it off.
  • 3 weeks later...
Exactly what he says, I did this on my silvia and going to do it on my GT-T when I get my R34 Brembos.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
