  • Replies 328
Wow this has gotten huge,my 4 year old grandson is coming with me,he loves skylines,and this will be the most he has ever seen in one spot,he is gonna be gobsmakt when he sees em all. :P:(
I've got a place down the south coast too.
Introduce yourselves to me when you arrive!
I'll show him my bright red "PANIC" button (on the dash of course) hehe.
Happy Birthday btw!
Cheers Tez
OK, sorry for the break, we have had an unprecedented umber of people interested in the cruise.
Which is great....but also makes it harder for us to organise.
So, 2 things:
1/ This cruise is being run by SAU NSW Inc (the club) and under a CAMS permit. We looked into making this a members only event due to the possibility of silly behaviour. We have decided not to do so for this year.
We will have manageable groups of cars with an SAU exec at the front and rear of each group. The lead car will stay at or under the speed limit all the way. If you pass the lead car you are no longer taking part in the cruise, your details will be recorded and you will not be welcome at future SAU events. Same if you do anything silly, we cannot risk loosing CAMS' backing in running these events. We will happily report dickheads to the police, imports already have a bad enough reputation.
2/ The place we normally go for lunch has only 50 seats available. We will make a booking Thursday afternoon for every person we have received a deposit from. If you do not deposit, or it is received after that you will have to make your own lunch arrangements elsewhere in singleton. There are plenty of other options to choose from.
Details for lunch deposits are:
Account Name: Skylines Australia NSW
Bank: NAB
BSB: 082356
Account Number: 546393766
Amount: $20 per person
Remember your payment will take at least 24 hours to come through, so do not delay if you want a lunch booking.
We're all really looking forward to this cruise, its going to be great! Just stay home, or head up there some other day if you are not willing to stick to the behaviour rules above.
Finally, please remember this is a charity cruise for the RSPCA...some bring along a gold coin or similar to donate to a great cause! Last year we raised almost $500 for the cancer council.
So do you mean today or next Thursday?
Just a question.. is the $20 just a fee or is it going towards our meal.. eg i deposit $20 for booking and my meal costs $22 I only pay the remaining 2 dollars?
sorry I'm having a bad night communicating (maybe its the grog?)....the $20 is a deposit against your lunch....we will hold it, make a booking based on the number of deposits received in our account by thursday 22/10. We will pay the deposit against the cost of your lunch....so yes in your example you only pay $2.
this cruise is about making money for the RSPCA, nto the club. We are just making sure we are not overbooked for lunch ;)
Why are all the cruises and events in Sydney located in rural/less populated areas. What about south western sydney, say like liverpool - campbelltown area?
Ummm, you musty miss the one that starts in cambelltown:) It generally called the 'old KK/maccas cruise' there has been about 5 this yr alone:) keep your eyes out")
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
