I bought an X-Force cat and noticed a fair difference going from de-cat pipe to that...both power and sound. The RB lost alot of raspyness that it had with the straight pipe. I'm pretty sensitive to changes in the feel of an engine/car though (I get very paranoid about engine problems and the like).
One thing I didn't like about it was the sensor that plugs into the cat...the bung on the cat wasn't the correct size to fit it in. Also the flanges it came with weren't that good when it came to lining up.
Long story short I'm back to de-cat goodness and washing the back of my car every couple of weeks.
  • Replies 47
mine all lined up nicely and the sensor fitted perfectly
mind you i did get the full system with the cat for the 33 so i guess thats why.
Perhaps the cat you got was just a generic 3" so just had the most common cat converter sensor size in it?
I got a quote today for a 3 1/2in X-force turbo back stainless system for $1600 supplied. I was gonna probably go with the xforce but after reading this i probably wont with all this about the cat business, is there another simliar alternative that would bolt on like the xforce and wont cost too much more?
You have to pay to play.
As mentioned if you dont have 300+rwkw there fine, if you are aiming for 300+rwkw then you better be prepared to spend money, cheap isnt an option if you want it reliable.
the odd backfire would point towards airflow meter, or on a cold night the air is alot thicker (more oxygen in it) could be a bit lean, reasons are many for back fire, no offence but your giving miss infomation.
no offence mate, but your miss information is way worse. cold air is not thicker at all. air density decreases with an increase of altitude, as does air pressure, nothing to do with air temp, although o2 is more present in air with a higher density and lower temp.
back on topic, im keen on a x force cat too, does anyone know the length of it? i know the stock cat for an r32 gtst is 310mm, so hoping the xforce will be very similar.
Edited by adamskill
I Have a full xforce 3.5inch turbo back on my R32gtr, for 2years now it has been flawless, it also gives out a wonderful RB26 note very deep tough sound. I have the xforce metal cat and make 362rwkw and I don't have any of these issues others are talking about.I tried a decat ran it up on the dyno and only lost 3kw. I did this out of curiosity back then as I to wanted to see the flow restriction I thought it would have.
Well hardly any and with this power my Garrett turbo -9s became the restriction not my exhaust. So honestly i say they are great and don't believe everything you here.
Cheers,
Dave
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
