Have you seen any more power Nathan from more boost?
Surely valve float isnt too far off
my standard coils were breaking down at 23psi and i haven't had a chance to put it back on the dyno since i replaced them.
how do you guys control boost with those sort of setups? wastegate mounted off the exhaust housing?
i changed from a .82 to 1.06 (havent yet retuned) and added a bigger gate (44 to 48mm) and it started to boost creep madly from there.
i've got a twin scroll manifold with twin 38mm gates, so far boost control hasn't been a problem but we'll see what happens when the 1.06 housing goes on.
  • Replies 112
the manifold is probably your issue the gate pipe exit angle is pretty severe and we have had to mod a few to make work properly.
here is an original picture of the manfold. URAS do you have any pics of your modified ones, would be interesting to have a look. id also be keen to have a look at a few that are straight out of the housing.
its since had the wastegate pipe moved further into the gas flow, and ive upgraded for a 48mm gate (from a 44).
i think just putting it off the housing will solve the problem once and for all hopefully. the manifold maker has been mucking around with this for ages now and i dont really want to spend the $$$ on a 60mm gate even though that will fix the problem.
will be interesting to see what sort of power i can get.
8.5 comp ratio with stock r32 head with valve springs and camgears 1.06 housing. 310kws came on the .82 on 19psi.
Edited by SirRacer
Wasnt there a thread about this somewhere....all merge collector manifolds with gt35r turbos and up seem to have this issue...the manifolds flow so well that it bypasses the pickup for the gate, smaller turbos on those manifolds seem to have enough back pressure in there to force gas out the wastegate.
To fix it, the wastegate pipe needs to protrude further into the gas flow inside the collector to catch more gas and direct it out...otherwise block it off and put the wastegate off the exhaust housing. Weve done that fix several times now and it works great. The manifold builders know of the issue, but i dont think they like the idea of disrupting the excellent flow they have through there. But i think perfect boost control is quite important. Probably abit more so then having perfect exhaust flow/spool.
Yep - i even tried a quick search for it last night actually hehe.
Pretty sure it was the 1.06 housing ye?
I remember a thread on it, quite detailed, but just didn't have the time to find it.
Would be 12 months ago now at a guess.
Its just plain bad design, 90 degrees off the collector is never gonna work on genuine high hp stuff and it doesn't. We have had to extensively modify them (dual outlets to gate) to work properly.
Thanks mate, that looks good.
I found another from the Heat Treatments world record holding GTR. This is from their new turbo setup (looks nasty).
http://www.htlracing.co.nz/images/200935020th002_008.jpg - I thought the distance between the housing and the gate is quite interesting.
hmmm, no idea why they would do that. i would have thought for optimal operation of the gate and gas flow, the gate could sit right on the housing. so that the piston/button in the gate is level with the inside surface on the housing. no doubt they would have their reason tho.
i also wonder whether having the gate coming out of the housing is much better for spool. considering the fact that exhaust gas spools the turbo, having it run through the exhaust housing (and therefore wheel) rather than been bled off, must be a tiny little bit better flow and responce wise?????
having a gate off the housing has nothing to do with spool. all it does is control boost. not how fast it makes boost.
the downside to having gates off housing is that you pretty much kille off any chance of a resale as it's not a highy wanted modification. personaly it just seems very backyard job.
that's my view on it anyway.
just remember you don't have to have theg hate off te housing. it is 99% th fault of a badly designed manifold. although it is alot cheaper then buying or sometimes modyfying the manifold
Edited by Jap_Muscle
I'm sorry buddy but you've got it completely wrong. the only reason a manifold has problems controlling boost is of poor design. if you bought a manifold like this you either
a. do not know how a forced induction system works
or
b. you wasted money on a shit manifold.
you need to understand that building boost and expelling boost are just as important as each other. if you only have one your fooling yourself
or
I'd be blaming the guy making the manifold not the end customer! The manifolds in question come from the most popular manifold makers in Aus....
not poor design at all, its poor placement of the wastegate port.
which is poor design
aint you also running his manifolds?
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
