Make sure you get a Genuine Garrett "-IW" internal gate rear housing - Not some cocked up/ported piece of shit.
That is where the boost control problems come from.
If it is not a 100% .63 Garrett -IW housing - do NOT buy it no matter what you are told.
  • Replies 44
^^^ Necessary input. Lol. Nothing wrong with internal gate for those who like consistency.
Another turbo option to go for:
GT2871R. It's a garrett, but more closely related to an HKS. Bit small, but a lot quicker response. most that you'll find is .60 A/R compressor housing, but turbotech over here has one for about 1800 i think it was with a .76 somehow.
I'll keep a close eye on this thread. i'll be doing similar things with my engine.
Can't buy PFCs new anymore can you? Like, from a wholesaler? What'd be the other way to go? I'm sorry to succumb to shameless advertisement, but if haltech can produce enough cash to buy a R35GT-R as a promo car, they're obviously doing something right.
You seem to want a low cost direct bolt on option
What i have learnt there is nothing that is 100% bolt on when it comes to turbo's, will always need some custom work. Had to make custom dump+front pipes along with a bunch of other stuff. Always have an extra 1-2 grand on top of what you expect it to be.
I would go the nismo 740cc injectors as the price different between them and the 555cc is under $100 for the set.
Going for a GT3071 GT3076 etc with the Garrett turbine housing will require all those extra mods from oil & water lines, new dump, intake mods, heat shielding and the costs to get up when you go this way.
GCG hiflow bolts straight back on.
Hypergear has been working hard on making some of their turbos bolt on applications (with minor oil or water line mods?!)
HKS GT-RS bolts back on but with braided lines.
HKS GT2835ProS has a separate dump to the front pipe which may be an issue if you already have a 3" dump/front but otherwise the kit comes with all you need to bolt back on.
Have a look at precision turbo, in the US. They have plain and bb cores, not water cooled, v-band dump, billet comp wheels, 3inch or 4 inch inlet etc good pricing too.
I just bought a PTB5557... I think they're around 875is USD retail.
You'd need a custom oil line ($40), custom dump with a v band flange ( v-band flange and 2 mandrel bends, like $100 tops), 2" 90 degree silicone elbow ($40), 38mm external w/g ($240) and stock manifold mods ($150 odd).
Just another option...
J.
LOL and who told you they don't spike boost? My old supra had a GT3582R Turbo with the twin flappers on the back. spikes boost like f*ken spastic run 22psi with wastegate fully lose and no dump. Had to take it back to MTQs to machine out wastegate port and fit a bigger flappers. They are just piece of casted steel housing machined to shape like any one elses Nothing special at all and certainly do not help on boost control.
Edited by kwickr33
am probably gonna get the hypergear GT3071r, will post result once on and dynotuned
got my Power Fc off ebay for $1060, just jap still advertise them for $2000 brand new as well as Z32's for $299 new
Was the topic at hand - the GT35?
No. It is a 3071 much different.
So keep your rather poor example, and lack of useful input, out of this topic.
No, just saying you are inputting information that you don't even know the nature of. reading some the rubbish you wrote makes me puke, and mislead other members.
I know your are the king of worriers at this keyboard world. This is just my 2cents
Edited by kwickr33
You are talking about a 700hp turbo & flow out the back, vs a 450-500hp turbo and the flow
They are not the same, and very different.
A Garrett IW rear end will easily flow a 450hp turbo's worth of air.
The GT35 IW is a different story, always has been a sticking point.
So - Sorry, but once again i must point out you are factually wrong about the GT3071 having problems with a IW rear.
Just because you had issues with a GT35, has little to no bearing on a much smaller turbo
A "GT2835R" IS a GT3071R , same family of turbine , same family compressor wheels .
The only reason HKS get this cartridge to work better than Garrett does is because they use GT30 based turbine housings in the six cylinder versions . If Garrett profiled their GT30 housings to suit the cropped GT30 turbine they would have a very useful unit .
A .
Edited by discopotato03
Probably worth doing a search and checking out the experiences BHDave had with boost creep on a 3071 with 0.63 IW Garrett housing.
I agree with Wolverine's comments about the product Hypergear are putting out there. There are a few options that seem like they're close to a bolt-up, and at the price point well worth a go. Following the Hypergear thread there seems to be quite a few satisfied owners and reasonably serious efforts to provide after sales support. It'd be interesting to inspect the 0.63 housing they use for the 3071 spec, and to know exactly what cartridge is used ie. if it has the full size 60mm or cropped 56.5mm turbine rotor.
GT-RS would also be a tidy option at the targeted power/performance level if you could source something for a reasonable price.
  • 2 years later...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
