Just looking at converting to E85 is all thought I'd ask a few questions on the conversion
It's definitely worth making the switch. Too many easy gains from it not to and it's becoming more and more readily available
Gee where to start, Needless to say the last week has been pretty full on.
After many a delay I finally got the car back on Friday. After noticing the car was on the dyno at 10:30am on Friday I expected to get a call around 12:30pm-1pm stating that its done. It came to 3:30pm and I hadn't heard anything so I gave them a call. Apparently the car ran out of fuel on the dyno during tuning and they had to go get some more (I dropped it off with a full tank). I let them know it takes me 2 hours to get there so if they know when it will be ready i can start heading there earlier so they arent hanging around waiting for me all arfternoon. Finally got a call back at 5:30pm stating that its nearly finished and to head down.
They advised on the phone that it made 630rwhp on 29psi, however the head was lifting and they wanted to "dial it back" a bit to make it safe for powerplay.
Arrived there at about 7pm and got chatting about the car. Even though the car has ARP head studs it was still lifting. I thought "righto at that pressure I guess it needs looking at". Then came the "Dialed Back" numbers. They ended up bringing it all the way back to 451rwhp on 15psi. I still and even now am surprised they had to drop it back so much to make it run safely. Due to the time of night and a bit of disbelief on my behalf I didnt go into depth about the lifting issue etc.
By the time we got the car loaded onto my mates tow truck and got it back home & back into the shed it was 11pm. After finishing off other setup jobs for powerplay the next day I got to bed at 12:30am.
NOTE : I DO have dyno sheets for both the 630 runs and the 451 runs. I will scan and upload them hopefully tonight.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
