Just looking at converting to E85 is all thought I'd ask a few questions on the conversion
It's definitely worth making the switch. Too many easy gains from it not to and it's becoming more and more readily available
Gee where to start, Needless to say the last week has been pretty full on.
After many a delay I finally got the car back on Friday. After noticing the car was on the dyno at 10:30am on Friday I expected to get a call around 12:30pm-1pm stating that its done. It came to 3:30pm and I hadn't heard anything so I gave them a call. Apparently the car ran out of fuel on the dyno during tuning and they had to go get some more (I dropped it off with a full tank). I let them know it takes me 2 hours to get there so if they know when it will be ready i can start heading there earlier so they arent hanging around waiting for me all arfternoon. Finally got a call back at 5:30pm stating that its nearly finished and to head down.
They advised on the phone that it made 630rwhp on 29psi, however the head was lifting and they wanted to "dial it back" a bit to make it safe for powerplay.
Arrived there at about 7pm and got chatting about the car. Even though the car has ARP head studs it was still lifting. I thought "righto at that pressure I guess it needs looking at". Then came the "Dialed Back" numbers. They ended up bringing it all the way back to 451rwhp on 15psi. I still and even now am surprised they had to drop it back so much to make it run safely. Due to the time of night and a bit of disbelief on my behalf I didnt go into depth about the lifting issue etc.
By the time we got the car loaded onto my mates tow truck and got it back home & back into the shed it was 11pm. After finishing off other setup jobs for powerplay the next day I got to bed at 12:30am.
NOTE : I DO have dyno sheets for both the 630 runs and the 451 runs. I will scan and upload them hopefully tonight.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
